Home -> Forums -> Construction -> Layout and House Plans -> Construction Layout
Construction Layout
Fri Jan 24, 2014Total posts : 1
amandeep
amandeep
Topic: Construction Layout
Hello. I want to build home on my plot with size 42.6x 42 feet. can you please suggest me some ideas/plans/layouts.
thanks
Fri Jan 24, 2014Post  #1
Dear Mr.Amandeep
1697
What is the actual layout plan for east south facing plot
Last answer on 12/29/2014 12:50:56 PM. by seema tyagi. Forum started by bsp
2263
PLAN FOR EAST NORTH ROAD 32 FT WIDE AND 45 FT DEPTH
Last answer on 6/3/2015 9:59:12 AM. by seema tyagi. Forum started by jagdish chand
2052
house layout
Last answer on 1/3/2017 1:20:31 PM. by S L Gupta (Civil Engg). Forum started by mahesh shukla
2019
to help layout plan for 33ft. by 39 ft.
Last answer on 11/21/2013 10:05:07 AM. by S L Gupta (Civil Engg). Forum started by firoz raza
3802
Orientation of Building
Last answer on 8/6/2010 2:09:05 PM. by narayan. Forum started by pooja
1940
1945
Eastern North Road, Plot Layout HOUSE PLAN GIVE ME SIR
Last answer on 11/18/2021 10:49:57 AM. by S L Gupta (Civil Engg). Forum started by MD NIRANJAN
1883
2155
Last answer on 10/25/2021 1:47:12 AM. by JAI PRAKASH. Forum started by mgmishra
3185
Last answer on 3/16/2017 11:32:26 AM. by S L Gupta (Civil Engg). Forum started by vijay jaswal
1950
I NEED LAYOUT FOR SOHP STIRCASE ,LOCKER ALMARAS ,OUR SHOE IS EAST FACING DUPLEX
Last answer on 8/29/2010 4:06:02 PM. Forum started by ANOOP JAIN
2615
it would be great if you could send the layout of this house
Last answer on 10/27/2010 6:05:42 PM. by Lydia Jenifer. Forum started by Lydia Jenifer
2837
I need a detailed layout of above picture.
Last answer on 11/13/2021 12:05:33 AM. Forum started by sachinjoshi69
1891
plz send me layout of duplex flate of area 1300sqft
Last answer on 1/31/2011 12:28:10 AM. Forum started by ajeet kumar
2491
2664
procedure of building layout detail
Last answer on 3/15/2011 6:11:55 PM. by Mohini Sharma. Forum started by kanwer sajjad
2388
Last answer on 11/21/2013 10:05:53 AM. by S L Gupta (Civil Engg). Forum started by RAGUVINDER SINGH
2188
I want house layout according to vastu
Last answer on 11/21/2013 9:58:18 AM. by S L Gupta (Civil Engg). Forum started by Piyush Kothari
1562
2691
2924
2188
2184
2793
4520
1890
2284
2267
2767
3464
2356
1968
2242
3595
2324
2091
2792
1548
2114
