Home -> Forums -> Construction -> Start Construction -> Construction Process Step by Step
Sat May 30, 2015Total posts : 4
Bimlendra Jha
Bimlendra Jha
Topic: Construction Process Step by Step
Dear Friends,
What is the detailed process for the constructing a new Building if its start from planning and ends at Selling / possession, please advise if any link is available with this kind of information.
I am working on making construction process manual / SOP for projects (Planning to Possession)
Bimlendra Jha
Mon Jun 01, 2015Post  #1
Dear jha
See the link below.
http://www.gharexpert.com/articles/Start-Construction-1528/Guidelines-while-Starting-Construction_0.aspx
http://www.gharexpert.com/articles/Start-Construction-2368/List-construction-activities-in-sequence_0.aspx
http://www.gharexpert.com/articles/Start-Construction-1973/Gharexpert-can-save-you-money-during-construction_0.aspx
Mon Jun 01, 2015Post  #2
Please check
Attachments: 1.jpg Mon Jun 01, 2015,
2.png Mon Jun 01, 2015,
3.jpg Mon Jun 01, 2015,&n
Wed Jul 01, 2015Post  #3
Bimlendra Jha
Bimlendra Jha
Dear Jay Prakash,
Can you share editable file please?
Bimlendra Jha
Fri Jul 03, 2015Post  #4
Typical construction steps for a single-family or small multi-family house are:
Develop floor plans and obtain government building approval if necessary
Clear the building site
Pour a foundation with concrete
Build the main load-bearing structure out of thick pieces of wood and possibly metal I-beams for large spans with few supports. See framing (construction)
Add floor and ceiling joists and install subfloor panels
Cover outer walls and roof in particleboard or plywood and vapor barrier.
Install roof shingles or other covering for flat roof
Cover the walls with siding, typically vinyl or wood, but possibly stone or other materials
Install windows
Frame out interior walls with wooden 2x4s
Add internal plumbing, HVAC, electrical, and natural gas utilities
Building inspector visits if necessary to approve utilities and framing
Install interior drywall panels and fiberglass insulation to make walls and ceilings
Install bathroom fixtures
Spackle, prime, and paint interior walls and ceilings
Additional tiling on top of drywall for wet areas, such as the bathroom and kitchen backsplash
Install final floor covering, such as floor tile, carpet, or wood flooring
Install major appliances
Unless the original owners are building the house, at this point it is typically sold or rented.
2722
Kindly assist with step by step procedure of building a Duplex.
Last answer on 12/31/2020 2:07:47 AM. by Gunjan Utraja. Forum started by Tuneer Garga
2197
method of road structure, step wise detail caculation of material
Last answer on 3/15/2011 6:14:15 PM. by kanwer sajjad. Forum started by kanwer sajjad
2244
how many steps made at home.
Last answer on 7/4/2012 8:11:12 AM. by Amit Hasija. Forum started by Saurabh
3031
Last answer on 4/1/2013 3:23:48 PM. by akmurty1. Forum started by kjeevanrao
1749
vastu for steps please
Last answer on 1/9/2014 11:02:06 AM. by S L Gupta (Civil Engg). Forum started by lakshmi
5929
Last answer on 7/4/2020 2:13:40 AM. by JAI PRAKASH. Forum started by P Pavan Kumar
2148
how to read structural drawings//Basic steps??
Last answer on 8/27/2015 6:43:26 PM. by JAI PRAKASH. Forum started by Maryanne Robynn Delana
2052
1461
DOES HAVING STEPS IN THE HOUSE EFFECT IN ANY WAY?
Last answer on 8/8/2017 12:10:09 PM. by S L Gupta (Civil Engg). Forum started by MADHU
1455
Steps was constructed in south West corner of my house .is it correct
Last answer on 8/8/2017 12:09:44 PM. by S L Gupta (Civil Engg). Forum started by Raja
2629
25*18south facing house with bedroom,toilet kitchen and hall with steps
Last answer on 11/13/2017 1:46:28 AM. by S L Gupta (Civil Engg). Forum started by Harish
2829
1765
base for velvet touch paint
Last answer on 12/29/2015 12:53:11 AM. by JAI PRAKASH. Forum started by Anu
1997
Hie
Last answer on 7/3/2020 11:37:56 PM. by JAI PRAKASH. Forum started by Maryanne Robynn Delana
1815
how to start a commercial interior project steps and precautions to flow...
Last answer on 6/21/2021 4:15:41 AM. by sandeep yadav. Forum started by sandeep yadav
roofing on open terrace
3696
Hi,iam planning to buy a house but i feel steps are in kuberasthan.can some one
Last answer on 10/10/2021 10:31:52 PM. by S L Gupta (Civil Engg). Forum started by lakshmi
1839
can we enter into the house getting down the steps, if it happen to construct so
Last answer on 1/21/2022 4:05:50 AM. by TanyaHerrera. Forum started by Kirubhashankar
staircase ,step & riser
Last answer on 8/6/2011 2:49:12 PM. Forum started by shabbir ali
3312
2312
What preliminary steps should be taken before terrazzo tile flooring?
If any tile is not in perfect square shape, it will spoil the entire flooring.
How to Install a Sink
Installation of kitchen sink requires just few tools,material and a beautiful sink according to your needs. Read the s..
How to Build Stair Steps
What are the important steps of maintenance after installation of blended marble vinyl flooring?
Important steps of maintenance after installation of blended marble vinyl flooring.........
Fire
Fire Extinguisher
Fire Extinguisher help avoid accidental fire in the kitchens or homes. It extinguishes not only the fire but saves our..
