Home -> Forums -> Construction -> Layout and House Plans -> Construction Quality check
Sat Feb 14, 2009Total posts : 1
Khushru
Khushru
Topic: Construction Quality check
Hello All,
I wanted to know how we can get the construction quality of a house checked externally. Are there any govt. / non. govt. agencies who do this ?
I have purchased a house and within 6 months we can see cracks in the wall, so I wished to get the quality checked before we take some action against the builder.
Thanks.
Tue Apr 21, 2009Post  #1
yogi
yogi
Post subject: Construction Quality Check
After construction of the house, you can check the quality of construction using the tips given below.
  1. Find cracks in walls by inspecting physically.
  2. Check dampness in walls, roof of the house and ceiling of toilet.
  3. Get samples of construction materials tested from any reputed laboratory such as “Shri Ram Test House” in New Delhi for following tests.
  • Bricks for crushing strength test.
  • Bricks for efflorescence test.
  • Bricks for water absorption test.
  • Analysis of cement mortar to obtain ratio of mortar used in construction of house.
  • Analysis of cement concrete to obtain ratio of cement concrete used in construction of house.
23866
3492
How to Identify best white marble ?Does any one know how to check the Quality of
Last answer on 12/31/2020 2:19:17 AM. by anil. Forum started by anil
2041
estimation
Last answer on 4/30/2013 12:39:09 PM. by S L Gupta (Civil Engg). Forum started by dan
2501
Wood quality check
Last answer on 9/1/2015 4:22:59 PM. by JAI PRAKASH. Forum started by Vijay
1529
2877
Labour rate
Last answer on 7/4/2020 2:47:30 AM. by S L Gupta (Civil Engg). Forum started by M Prabhu
1902
point to be check befor tile application
Last answer on 9/12/2013 12:12:08 PM. by S L Gupta (Civil Engg). Forum started by archi
1881
check this
Last answer on 7/14/2010 6:48:24 PM. Forum started by nayma
1941
Last answer on 5/24/2012 5:08:53 PM. by S L Gupta (Civil Engg). Forum started by gaju
857
Last answer on 1/27/2022 6:31:12 PM. Forum started by Rahul T Pal
2245
2569
3023
check my DESIGN For my on construction house (front face)
Last answer on 1/5/2022 8:39:10 PM. by JAI PRAKASH. Forum started by maddy
2539
Determining the Quality of Construction of a Built House
Last answer on 9/26/2010 10:33:55 PM. by Ajit Tareeka. Forum started by Solomon
2286
Last answer on 7/4/2020 3:34:50 AM. by S L Gupta (Civil Engg). Forum started by yasothabalanr
2440
2012
coarse aggregate
3543
Which are various types of marble for flooring ?
Last answer on 9/8/2013 12:22:30 AM. by Sri. Forum started by shain thomas
3166
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2241
3595
2324
2090
2792
1548
2114
Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident..
Water for Construction
