Home -> Forums -> Construction -> Start Construction -> Construction Specifications
Wed Feb 13, 2013Total posts : 3
Vikram
Vikram
Topic: Construction Specifications
Hello All,
I am planning for a construction of a house of about 1600 Sq.Ft. I have approached a builder who has given me a specification as attached.
The price quoted per sq.ft is @ 1550.
Please let me know if this is according to the market standard.
Vikram
Attachments: Specifications (1).docx on Wed Feb 13, 2013,&n
Thu Feb 14, 2013Post  #1
Dear Vikram
      Your file is not open and you have not mentioned the place of construction as there is very much differance of rates from place to place. Secondly The cost per sqft is on higher side. Thirdly the cost calculation is depend upon the plan of the building including height and elevation of the building with the specification used in the building. In my view if you want detail cost of construction then prepare detail estimate according to drawings and specifications. A small amount expenditure give you lot of information about quantity of material, rate and specifaction.
Thu Feb 14, 2013Post  #2
Vikram
Vikram
Hello Mr. Gupta,
Thank you very much for the reply. The place is in Bangalore and the area is Kengeri. If the attachement is not readable, i have pasted the specifications.
Even I had the same feeling about the cost. I am waiting for a detailed bill of quantity and I would contact you as soon as i get that.
SPECIFICATIONS
1.   STRUCTURE and WALLS:
a)    RCC framed structure with Cement concrete solid Block works. Internal and External Plaster (the internal Walls thickness 4-6 inches) and (the external Walls thickness 8 inches).
Cement:
b)   For M 20 or higher grade of Concrete – ACC / Coramondal King Equivalent. Basic Rate – 318 / Bag.
c)    For non structural elements – Like PCC, DPC etc – Deccan / Jk Cement. Basic Rate – 290 / Bag
d)   For Block Works – Deccan / JK 43 Grade / Equivalent. Basic Rate – 285 / Bag.
e)    For Plaster, Tile, Water Proof and balance activities – Jk 33 Grade / Jai Joythi Equivalent. Basic Rate – 285 / Bag
f)     Steel – Fe 415 Grade. Basic Rate – 48000 / Ton
2.   FLOORING:
a)    Ceramic and Vitrified Tiles like Kajaria/ Regency (Mat or Glossy flooring as per the First Party choice) Basic Rate – 40 / SFT.
3.   WALLS:
a)    Internal and External Plaster and Acrylic Emulsion Paints for Interior and Exterior Walls
4.   FIXTURES & FITTINGS:
·         Main Door and Pooja Door - Teak Wood (25mm) (without curving)
·         Other Doors - Sal wood door frames with flush doors, Europa / Godrej / Daisy Equivalent Ironmongery [Water proof doors for Bathrooms]
·         Windows - Powder Coated Aluminum Windows with 4 MM Glass and Mosquito Mesh (min 7-10% NBC, if required the bigger size the difference to borne by the First Party) with Iron grilled for safety.
·         Emulsion Paint for Doors.
·         Stair Case  Railing and Windows Grills - MS
5.   PLUMBING / SANITARY FITTINGS:
·         Jagqur Continetal Range Bath Room Fittings
·         Cpve Internal Plumbing - Ajay / Ashirwad / Astral / Vectus Make line
·         Soil Waste - Kisan / Astral / Prince / Supreme Make
6.   ELECTRICALS:
·         Internal Wiring – RR / Lapp / Anchor / Polycab / Kei Make.
·         MCB and other Electrical Switch Gear – Indo Asian / ABB / Schneider / LT Make.
·         Switches: Salzer / ABB / Anchor / Toyama / Honeywell equivalent.
7.   PICKET FENCING
8.   RAIN WATER HARVESTING
9.   SUMP AND OVER HEAD TANK
a)    8” Block Works OHT of Hitech / sintex / Cauvery Make 1000 Lit  Capacity, UGT Sump 3000 Lit Capacity in    Block Work with RCC Slab
b)   Water Supply will be provided by borewells.
    10. OTHER SPECFICATIONS
a)    Height Of Wall Tiles For Bathrooms Will Be 7.0 Ft.
b)   Height Of Wall Tiles Above Washbasin Other than Bathroom Area Will Be 2.5 Ft.
c)    Height Of Wall Tiles Above Kitchen Platform Will Be 2.5 Ft.
d)   Kitchen Platform will be fitted with Either Granite or Stainless Steel washbasin Depends On Customer Choice.
e)    Height of Wall Tiles for Poojaroom Will Be 7.0 Ft.
f)     O.H.T Will Be Fixed Above Staircase Headroom with a M.S.Ladder For Acess.
g)    Paraphet Height At Terrace Area Will Be 3.0 Feet.
h)   1 H.p Motor Will Be Provided By Second Party to Each Indivual House.
Thu Feb 14, 2013Post  #3
Post subject: Construction Cost estimate
Dear Vikram,
Cost of constriction depends on so many points like:-
• What you want to construct?
• Rates of construction materials and quantity to be used.
• Labor rate etc.
You may order a detailed estimate at:
In addition you can send an email to support@GharExpert.com for further help.
3278
Re. house construction specifications from the contractor
Last answer on 10/12/2021 12:34:05 AM. by Navneet Jharia. Forum started by vignesh_mp
3258
2096
specifications of building materials used in construction industry
Last answer on 9/6/2015 12:27:20 PM. by sanjay agarwal. Forum started by Star Koziba Leladi
2511
2123
Cost of Construction
Last answer on 8/19/2013 11:11:40 AM. by S L Gupta (Civil Engg). Forum started by Naveed Mohamed
3560
Cost of construction
Last answer on 3/19/2013 11:44:19 AM. by S L Gupta (Civil Engg). Forum started by saurabh ramya
4387
Specification for house construction
Last answer on 9/25/2020 7:00:31 AM. by . Forum started by kumar
2121
underground water tank
10902
Last answer on 2/8/2021 2:14:37 AM. by John. Forum started by karthik
1627
Good morning ... can u please let me know the cost,specifications and estimation
Last answer on 10/17/2016 12:12:48 PM. by S L Gupta (Civil Engg). Forum started by syed ameeruddin
2662
sir want the detail specification of acp cladding , such as thicknesss of sheet,
Last answer on 1/17/2013 12:27:08 PM. Forum started by somashekhar
2897
2417
can u give me the specifications of material shown in this picture and appox. ar
Last answer on 7/3/2019 12:31:26 AM. by Ajit Tareeka. Forum started by romaadhikari
1652
SPECIFICATION INPUTS FOR MY HOUSE PLAN
Last answer on 6/27/2016 2:06:28 PM. by S L Gupta (Civil Engg). Forum started by M Prabhu
3163
APP membrane
2035
Dear Gupta sir,Can you please suggest the detailed specification for a good foun
Last answer on 5/8/2013 12:14:58 PM. Forum started by nithun
2391
BUILDING MATERIAL RATES & PETTY JOB RATES
Last answer on 5/15/2013 12:16:14 PM. by GULSHAN RAI GULATI. Forum started by GULSHAN RAI GULATI
1515
Builder Fees Estimate
Last answer on 4/18/2016 1:18:20 PM. by S L Gupta (Civil Engg). Forum started by Gurpreet Bajaj
3310
Specification of Water
Clean and clear water is quite suitable for construction work.
Specification of Steel
Sanitary
Gray
Gray Cement
Do you know the strength of a building depends on the quality of cement? Cement/ Gray cement is one of the most import..
