Ground work
Fri Sep 19, 2014
Hameed
Topic: Construction cost to build 1135 sq.ft
What will be the construction cost to build 1st floor of size 1135 sq.ft, in Chennai, Maduravoyal.
Fri Sep 19, 2014
13.5-17.0 lacs.
Sat Oct 25, 2014
Approx. cost would be 17 lacs
2772
Last answer on 7/12/2018 5:49:08 PM. by
Hameed
Last answer on 6/9/2016 11:04:10 PM. Forum started by
Vignesh
Last answer on 10/18/2014 4:08:18 AM. by
bhatu
2557
Last answer on 10/15/2017 1:22:37 AM. by
gautam kumar
gautam kumar
23866
Last answer on 7/8/2020 10:27:10 AM. by
sonu
2746
Last answer on 12/27/2016 4:34:02 PM. by
sathis
4735
CONSTRUCTION COST OF 3 STOREY BLDG
Last answer on 7/4/2020 2:47:14 AM. by
kavi77
shakirk78
3542
Contruction Tool
Last answer on 4/28/2012 2:57:09 PM. Forum started by
Bimlendra Jha
Last answer on 6/10/2016 10:49:55 AM. Forum started by
Vignesh
2708
type of brick
Last answer on 12/5/2013 11:14:47 AM. by
neelam rathi
8582
Last answer on 12/25/2013 2:07:19 PM. by
arunkrishna kannambadi
2006
Last answer on 11/10/2016 5:24:45 PM. by
Sagar
1542
I want to construction of a double stored building low cost total 1800 sq ft no
Last answer on 7/13/2020 3:16:36 AM. by
Samaresh Mohanty
3830
Last answer on 5/5/2014 12:57:31 PM. by
lb sharma
3083
Last answer on 11/3/2016 11:02:29 AM. by
S.S.Dewangan
2176
Last answer on 1/27/2017 1:14:54 PM. by
Satishkumar
Satishkumar
12615
130 sq. ft. plot ka naksa for construction
Last answer on 8/16/2017 1:56:37 AM. by
Ravi
1777
Last answer on 8/8/2016 2:46:05 PM. by
arvindkori
2995
Karan
8160
software
Vaasku
sco4666
sagar suryawanshi
2730
Manish Singh
1833
lanterns
ARVIND GOYAL
3134
false ceiling
sabita laskar
2245
about construction
simran
1786
lowz
4154
Cement Coba
Last answer on 12/21/2021 8:15:49 AM. by
Prasenjit
3076
Water Harvesting System
sunny420
1676
Robert
1758
water tank
rodmotall4
sadanand
2058
sumit
1760
jitendra kumar
1634
Pool construction cost
Erling
Shardul
1994
sanyindias
2738
Regarding roof beam
Amit Kumar
Fire Stair case
mvxmanazxmfsm
tejas
2645
MOHD WAKEEL
2371
super structure
anil kumar
What is acre
How to Design a Garage
Orientation of Building
