Home -> Forums -> Construction -> Start Construction -> Construction cost
Construction cost
Sun Dec 26, 2010Total posts : 4
mahaveer
mahaveer
Topic: Construction cost
I want to build on to area of 1200sqft. i want to make 2 bhk.
i want to know approximate cost of foundation , flooring and roofing .
Mon Dec 27, 2010Post  #1
Dear abid
     For calculating the tentative cost you should use cost estimator tool given in the gharexpert.com website. If you want detailed estimate than you should send plan of the building with specification at the support@gharex.com.
Tue Dec 28, 2010Post  #2
UDAY SHANKER PRASAD
UDAY SHANKER PRASAD
Post subject: Construction cost
Dear Abid,
     It will be about 10 lakhs.
Wed Dec 29, 2010Post  #3
Mohan
Mohan
Post subject: Need help on estimating wood requirement for 2 B...
Dear All,
         Am looking for information on wood requirement for a 2 BHK (approximately 1400 s.ft) home am planning to build; I have enquired about the wood rates of different kinds normally used for residential homes. Would like to know the approximate CFT  needed for me (2 BHK, approximately 1400 s.ft), based on which I would need to plan the kind of wood to be used (to contain the expenses within the allocated budget). Many thanks in advance.
Thanks & Regards,
Mohan.
Wed Dec 29, 2010Post  #4
Mohan
Mohan
Dear All,
     Am looking for a information on wood requirement for a 2BHK home (approximately 1400 s.ft). I have enquired about the rates of various kinds of wood normally used for residential home construction in southern part of India and have taken quotation for the same. Now Am in a need of approximate CFT requirement for my home, so that I can decide on the kind of the wood to be used ( as I I have allocated a fixed budget for wood expenses and would like to contain the expenses within the budget allocated). Any chart or pointer to the document which talks about the wood requirement breakups like... CFT needed for 8x6 window, normal 7x3 door, regular 6x4 cot...etc., would be really of great help. Requesting you to provide me some pointers on this direction. Many thanks in advance.
Thanks & Regards,
Mohan.
6107
What is construction cost
4075
4819
2363
2691
2770
1792
2190
7420
750 Sqft Construction
2446
2573
1922
Last answer on 10/7/2020 10:22:43 PM. by S L Gupta (Civil Engg). Forum started by siva
2136
2206
2988
Sir I WANT TO KNOW THAT HOW MUCH CONSTRUCTION COST OF THIS HOUSE WILL BE EXCEPT
Last answer on 7/17/2013 11:42:13 AM. by S L Gupta (Civil Engg). Forum started by mahesh
4071
RCC consultant fee
Last answer on 12/4/2021 9:54:41 PM. by S L Gupta (Civil Engg). Forum started by milind jadhav
3478
I want do construct a home, plot size (20x50)feet.What is the construction cost
Last answer on 3/25/2016 3:05:19 PM. by S L Gupta (Civil Engg). Forum started by Santosh Singh Bhadoria
2892
1970
cost of construction for large span of 60'
Last answer on 10/30/2014 12:27:22 PM. by Amit Hasija. Forum started by amit jain
2482
3309
3321
4453
4026
2251
2728
4237
5211
2397
2322
2025
2463
2142
3216
2075
12548
2190
2033
2754
