Home -> Forums -> Construction -> Start Construction -> Construction of house without pillar
Mon Sep 08, 2014Total posts : 3
karthik
karthik
Topic: Construction of house without pillar
I have planned to build a house of build area 895 sq,ft. I got specifications from a builder using column post, lintel beam, etc. Construction is in coimbatore, tamilnadu
Is it safe to build without pillar.
I have attached the specifications here with kindly check and let me know your suggestions,
Attachments: spec.doc on Mon Sep 08, 2014,&n
Mon Sep 08, 2014Post  #1
Dear Karthik
           It is better if you have proper structural design. The house can be built without pillar by constructing load bearing walls.
Mon Sep 08, 2014Post  #2
karthik
karthik
Dear Gupta,
Thanks for your suggestion. Have you gone through the specifications i have attached.
As im not aware of construction details, i need some details from you. Kindly go through the basement and super structure specifications and tell me it is ok and i can continue with that specifications.
Wed Sep 05, 2018Post  #3
         Thank you.
12462
First floor construction
2695
2525
2604
Renovation of old house
Last answer on 5/24/2013 5:06:03 PM. by chandrakanth. Forum started by chandrakanth
3238
4388
18435
3608
5124
3793
15363
2nd floor construction
2931
FLY ASH BRICKS
Last answer on 6/27/2009 12:07:21 PM. by Kranap. Forum started by mamta
2153
8258
How much weight can the pillars take?
Last answer on 1/19/2011 1:22:06 PM. by rajkumarbn. Forum started by rajkumarbn
2377
Large room without pillars in middle
Last answer on 9/30/2013 11:11:56 AM. by S L Gupta (Civil Engg). Forum started by Suresh S
3364
cost saving in construction of house
Last answer on 8/17/2020 2:10:30 AM. by foro. Forum started by raviprakash
3610
3247
Building a house in Kolkata Rajarhat area few initial questions
Last answer on 2/15/2013 12:40:16 PM. by DK. Forum started by DK
3312
2236
2717
2313
2061
Brick Pillar
Why
