Home -> Forums -> Construction -> Layout and House Plans -> Construction plan
Construction plan
Fri Dec 20, 2013Total posts : 1
Dr Ranjan Biswas
Dr Ranjan Biswas
Topic: Construction plan
Want to get a plan for my newly purchased land.The plan should be as per VASTU.
The approaching road is only 8.5 ft wide and ends 6 ft beyond/after my land. The garage door should be much wider for turning by back gear (Ford Figo-12.6 ft X 6.3 ft).
Road on SOUTH side. East side empty and low Govt land. West and North habitat.
Plot 36 ft wide (east-west)and 47 ft deep (south-north).
Want at least 3 Bedrooms and 2(bath + toilet)rooms.
Attachments: Dropgate land.png on Fri Dec 20, 2013,&n
Fri Dec 20, 2013Post  #1
DearBiswas
2991
Pls send me construction plan to 30x60 sq feet plot
Last answer on 11/3/2016 11:02:48 AM. Forum started by Kiran Surve
1894
give me the detailed inner construction plan...
Last answer on 5/12/2014 12:40:44 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
2115
please,give me the full construction plan...
Last answer on 5/12/2014 12:39:42 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
2572
house construction plans for 20x30 site
Last answer on 7/4/2020 2:28:10 AM. by Amrit Bhagat. Forum started by ramu
1181
Please share some construction plan for 21*89 plot
Last answer on 2/5/2022 11:33:51 PM. by S L Gupta (Civil Engg). Forum started by KARAN KAPOOR
2506
Wanted the Construction and 3D plan according to Basic plan we have.
Last answer on 9/10/2014 8:26:24 PM. by seema tyagi. Forum started by Sricha Gupta
1822
Plot size 25*50 please send construction plan for combined family with three cou
Last answer on 5/26/2016 3:34:41 PM. by Beenu Phogat. Forum started by praveen solanki
1847
Hi,greetings, can any body help to prepare construction plan for my home to be s
Last answer on 6/26/2014 10:45:04 AM. by seema tyagi. Forum started by vasa
plan according to vastu for for my house construction
Last answer on 12/30/2014 11:54:37 AM. by krishna. Forum started by krishna
1230
Hi, Sir/MadamNeed construction Plan to Build Home. East Facing with 10 feet Road
Last answer on 4/10/2018 2:21:37 AM. by S L Gupta (Civil Engg). Forum started by Om Prakash Gupta
1487
Construction Plan and schedule for Plot in Pune
Last answer on 1/25/2017 12:02:43 PM. by S L Gupta (Civil Engg). Forum started by Deepak Kumar
1548
House Construction Plan
Last answer on 3/23/2017 11:42:47 AM. by S L Gupta (Civil Engg). Forum started by Asif
4733
CONSTRUCTION COST OF 3 STOREY BLDG
Last answer on 7/4/2020 2:47:14 AM. by kavi77. Forum started by shakirk78
2188
2041
BDA plot in bangalore
Last answer on 2/4/2014 11:07:24 AM. by S L Gupta (Civil Engg). Forum started by Vittal
12570
plan for 30*40 feet east facing house in south facing plot. plz send the plan fo
Last answer on 11/14/2016 11:10:55 AM. by Amit Hasija. Forum started by chakravrthi
2561
dear expert please give me lay out plan of north facing construction for 30*25ft
Last answer on 4/17/2012 5:50:14 PM. by manish. Forum started by manish
3830
2690
2924
2188
2184
2790
4520
1890
2284
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
How to Design a Garage
