Home -> Forums -> Construction -> Layout and House Plans -> Construction of residential home on new corner plot
Thu Nov 28, 2013Total posts : 1
Kapil
Kapil
Topic: Construction of residential home on new corner plot
HI NEED HELP OF AN ARCHITECT ON ASAP TO START THE CONSTRUCTION OF A NEW CORNER PLOT OF 104 SQ. YARDS
DIMENSION IS (30X31) FRONT IS 30 WANTS TO BUILD A 2 BHK  UP TILL GROUND + 3 FLOOR
Fri Nov 29, 2013Post  #1
Dear Kapil
1834
Last answer on 4/6/2017 10:05:57 PM. by Saurav anand. Forum started by prashant
2324
2507
3574
construction current rate
1588
what precautions have to be taken for construction on South-West corner plot (46
Last answer on 9/15/2021 2:53:51 AM. by RadyGoldy. Forum started by prashant
2241
i have purchsed daigonocaly plot for residential purpose there is south corner i
Last answer on 12/6/2010 1:50:39 PM. by S L Gupta (Civil Engg). Forum started by bipin brahmbhatt
3657
3299
Last answer on 8/11/2017 2:13:58 AM. by HOME. Forum started by Mitesh
2052
house layout
Last answer on 1/3/2017 1:20:31 PM. by S L Gupta (Civil Engg). Forum started by mahesh shukla
2001
2447
One place where i can get Architect, Contractor , Plumber, etc for New Home Construction
Last answer on 10/4/2011 3:02:53 AM. by sunny420. Forum started by sunny420
3830
2337
I want a residential home design low estimate
Last answer on 4/23/2013 11:32:19 AM. by S L Gupta (Civil Engg). Forum started by Dipankar Gharami
2665
plan for new construction 182 sq yd corner plot
Last answer on 1/10/2013 12:03:02 PM. by sonigupta. Forum started by kumarnaveen27
2668
Estimate require for new construction
Last answer on 7/3/2020 10:05:34 PM. by JAI PRAKASH. Forum started by Pradeep Patil
1181
6892
42-50 west south corner plot please give me vastu house plan 1500 to 1600 sft co
Last answer on 7/3/2020 11:38:42 PM. by seema tyagi. Forum started by muralipuram
3457
I want do construct a home, plot size (20x50)feet.What is the construction cost
Last answer on 3/25/2016 3:05:19 PM. by S L Gupta (Civil Engg). Forum started by Santosh Singh Bhadoria
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2241
3595
2324
2090
2792
1548
2114
Corner
Corner Bath Designs
Happy
Happy New Year 2009
