Home -> Forums -> Construction -> Start Construction -> Construction of shed of steel structure with CGI roofing
Sat Dec 29, 2012Total posts : 4
S K MOHINDRA
S K MOHINDRA
Topic: Construction of shed of steel structure with CGI roofing
What shall be rough cost per sq ft for construction of shed of steel structure, with CGI roofing and walls ordinary cc  flooring, for housing pump sets etc. The shed will be 10 m x 20 mt and 9mt ht. and costing shall be at Delhi.
Mon Dec 31, 2012Post  #1
Dear SK
            The cost of building/ shed is depend on the plan and specification used for the construction of building. However for general type of shed the rough cost rate is approximate Rs400-500 per sqft.
Mon Dec 31, 2012Post  #2
Ajay Chaudhary
Ajay Chaudhary
Post subject: need estimation of material for roof RCC work
Dear Gupta Sir,
I need to know the estimation for RCC work for Roof.
Specification of covered area is given below
38 feet X 25 feet..
I need to know how many Cement bags, Rori, Sand and iron rods I need. ?
I will be greatly thankful if u could plz provide quick reply.
Thanks..
Ajay
Tue Jan 01, 2013Post  #3
atlantaroofingcont
atlantaroofingcont
Post subject: Atlanta Roofers
Reading the recommendation really sparks a positive feeling for the team of your organization!! After all , we always look for the patient contractors, fair prices and time utilization with good wages segment and your products also seem diversified in their representation!!
Tue Jan 01, 2013Post  #4
Dear Ajay
      For cement concrete 1;2;4 for rcc slab 38x25 and 4.5'' thick the material required are as under
       cement= 64 bags
        B azri = 350 cft
         Coarse sand= 175-200cft.
         M.S. steel  bars 4 quental
 if you use cement concret  1;1.5;3 tha cement used is 84 bags.
4647
5275
Looking for good designs and estimation costs for 1000 sq yards marriage hall
Last answer on 6/27/2021 2:44:52 AM. by S L Gupta (Civil Engg). Forum started by faiz
2141
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by S L Gupta (Civil Engg). Forum started by sb
2211
1304
2248
2616
COLUMN nd LOAD BEARING
8256
How much weight can the pillars take?
Last answer on 1/19/2011 1:22:06 PM. by rajkumarbn. Forum started by rajkumarbn
4949
1943
Cost of Steel construction
1992
Residential complex
1885
Steel Erectors
1632
8420
Roof Beam crack
12252
2255
Hello members..i am building a small bungalow in Karjat .Mumbai.. and would like
Last answer on 1/27/2015 7:22:56 PM. by JAI PRAKASH. Forum started by FRANCO VAZ
1764
1893
column STRUCTURE
Last answer on 11/9/2015 3:11:28 PM. by S L Gupta (Civil Engg). Forum started by DURJOU KUMAR MONDAL
3310
2312
Earthquake
Steel
Steel Roofing
Roof Flashing
Is the ceiling of your house leaking? Apply roof flashing technique to prevent water leakage from the roof. Roof flash..
