Home -> Forums -> Construction -> Start Construction -> Contractor Quotation Problem
Sat Apr 05, 2014Total posts : 3
Atul D.
Atul D.
Topic: Contractor Quotation Problem
I have given a contract to a local contractor to construct 4 rooms (2 at front side, i.e. one at ground floor and one above it) and (2 at back side, i.e. one at ground floor and one above it which also include attached toilet - bathroom) at a rate of Rs. 1050/- per sq. ft. With material cost, labor cost (which include RCC, brick walls with plaster, flooring, plumbing,electric supply,drainage layouts,doors,sliding windows,painting,tiles in bathroom up to 7 ft.) in short a ready possession. But after constructing RCC of ground floor on both side and building walls(without plaster) the municipal corporation demolish the front side construction stating as illegal construction.  And now the work has stopped. So now the contractor is asking for money and had quoted me the rates as follows.
Total construction in details.
I. Front side ground floor:
1.      Slab area 15x15 =225 Sq.ft.
2.      Left side gallery(balcony) 12x3 =36 Sq.ft.
3.      Front side gallery(balcony) 18x3 =54 Sq.ft.
(225+36+54)=315 Sq.ft.
4.      Brick (6inch) wall of  8 foot height on 3 sides(1st wall 12 foot long,2nd wall 12 foot long and 3rd  wall 8 foot long) in which
i. 1st wall is complete wall
ii. In 2nd wall 6x4 foot area is left empty for window and  3x7 foot area is left empty for door.
iii. In 3rd wall 4x4 foot area is left empty for window.
II. Back side ground floor:
1.      Slab area 10x15 = 150 sq.ft.
2.      Gallery(Balcony) 3.5x10 = 35 sq.ft.
(150+35)=185 Sq.ft.
3.      Brick (6inch) wall of  8 foot height on 3 sides(1st wall 14 foot long,2nd wall 10 foot long and 3rd  wall 10 foot long) in which
i.  In 1st wall 6x4 foot area is left empty for window.
ii. In 2nd wall 4x4 foot area is left empty for window and  2.5x7 foot area is left empty for door.
iii. 3rd wall is complete wall
III. Back side first floor:
1.      4 columns of 7ft. each.
2.      Brick (6inch) wall of  3 foot height on 3 side(1 wall 15 foot long and other 2 of 7 foot long)
Now rate, he quoted me are as follows.
1.      50% of  original rate decided i.e. 50% of Rs. 1050/- per sq. ft. = Rs. 525/- per sq. ft.[for  RCC construction]
2.      20% of original rate decided i.e. 20% of  Rs. 1050/- per sq. ft = Rs. 210/- per sq.ft. [for brick wall construction]
3.      30% rate decided i.e. 50% of Rs. 1050/- per sq. ft. = Rs. 315/- per sq.ft. [for columns constructed on 1st floor at back side]
4.      10 % rate decided i.e. 50% of Rs. 1050/- per sq. ft. = Rs. 105/- per sq.ft.[for brick walls constructed on 1st floor at back side]
So he quoted me a sum of total Rs. 4,38,000/- whereas I have already paid him Rs. 2,10,501/- and as per the contractor’s quotation I have to pay him Rs. 2,27,501/- more.
Can you please help me and let me know if this quotation the contractor quoted me is right.
Attachments: I have given a contract to a local contractor to construct 4 rooms.docx on Sat Apr 05, 2014,&n
Sun Apr 06, 2014Post  #1
Post subject: Quotation Problem
Dear Atul D, Hello...! It is not clear from the quotation that it is for Both Floor (GF + FF) . Your Contractor has calculated it separately for Covered Area of both floor, as its some portion was unfinished and demolished..some deduction in rates  should be applied proportionately ...  Kindly take help of a qualified local Civil Engineer/ Architect to solve your problem after inspection on site....Regards.
Mon Apr 07, 2014Post  #2
Dear Atul
      If there are some disputed construction, than complete the other one which are legal.
Secondly as stated by Sh Navneet Jharia take local help in this matter.
Fri Jun 27, 2014Post  #3
Atul D.
Atul D.
Post subject: Thank you!
Dear Navneet Sir and gupta Sir,
Thank you for your kind help and advice. I am really thankful to you. Can you suggest me any architect in your contact or so in pune city.
Atul
1141
Please suggest the quotation to be fixed forthe carpentery work for interiors?
Last answer on 7/3/2020 10:57:09 PM. by S L Gupta (Civil Engg). Forum started by zakia sultana
2537
RCC column (pillar)
1939
Quotation from the Builder.
Last answer on 7/17/2013 12:27:25 PM. by S L Gupta (Civil Engg). Forum started by ananth
42597
Labour Cost for Roof RCC work
2043
problem facing by the direction and money problem
Last answer on 7/3/2020 10:58:15 PM. by S L Gupta (Civil Engg). Forum started by Bharath.gk
32663
Are there any problems in pasting tiles over an existing mosaic floor?
Last answer on 7/3/2020 10:21:35 PM. by Srinaath KS. Forum started by sunilbs9999
51
THE WORLD FAMOUS BEST INDIAN ASTROLOGER MOLVI AFTAB KHAN JI 91-8572082813.INDIA
Last answer on 10/9/2024 1:57:19 AM. Forum started by Molvi Aftab Khan Ji
48
Last answer on 10/9/2024 1:57:37 AM. Forum started by Molvi Aftab Khan Ji
43
Last answer on 10/9/2024 1:57:38 AM. Forum started by Molvi Aftab Khan Ji
Last answer on 10/9/2024 1:57:39 AM. Forum started by Molvi Aftab Khan Ji
Last answer on 10/9/2024 1:57:42 AM. Forum started by Molvi Aftab Khan Ji
32
Last answer on 10/9/2024 1:57:43 AM. Forum started by Molvi Aftab Khan Ji
31
Last answer on 10/9/2024 1:57:44 AM. Forum started by Molvi Aftab Khan Ji
Last answer on 10/9/2024 1:57:45 AM. Forum started by Molvi Aftab Khan Ji
Last answer on 10/9/2024 1:57:47 AM. Forum started by Molvi Aftab Khan Ji
32
Last answer on 10/9/2024 1:57:48 AM. Forum started by Molvi Aftab Khan Ji
30
Last answer on 10/9/2024 1:57:49 AM. Forum started by Molvi Aftab Khan Ji
30
Last answer on 10/9/2024 1:57:50 AM. Forum started by Molvi Aftab Khan Ji
Last answer on 10/9/2024 1:57:51 AM. Forum started by Molvi Aftab Khan Ji
3310
2312
Through
Swimming
Swimming Pool Maintenance
Maintenance of a pool is a major requirement that must not be taken lightly. Read this article to know tips on how to ..
Importance
