Raw Material
Contruction Tool
Contruction Tool
Sat Apr 28, 2012
Bimlendra Jha
Topic: Contruction Tool
Dear Experts,
Please advice how to calculate approximate cost of construction project, if the project is of 1200 sq. ft (wall area)
Bimlendra
1670
tool that add a valveto a 3/4in copper pipeunder pressure
Last answer on 1/17/2014 12:12:34 PM. by
anthony rodriguez
2906
I have 50X40 builtup areas with ground floor and want to make 1st floor but not
Last answer on 10/23/2012 11:46:28 AM. by
prabha
3801
Masonry tool ADZE
Last answer on 12/31/2020 1:57:31 AM. by
Boovarahan S
Boovarahan S
2265
can i know what the tools u used for this pain..its amazing one?!
Last answer on 5/4/2010 7:27:58 PM. by
Ajit Tareeka
rasha
2404
Where can I find investing tools for cryptocurrency? Does anybody here know the
Last answer on 11/23/2021 7:57:24 AM. by
jackthot
?rdyamk
1337
Look for electric paint roller tool ,just got a picture
Last answer on 11/1/2016 12:16:58 PM. by
Isaac
2099
Contruction & Renovation
Last answer on 1/17/2011 8:06:40 PM. by
paulsingh
2095
heat proofing the roof while contruction
Last answer on 9/17/2013 11:04:47 AM. by
vinayvaid
1887
Last answer on 11/29/2021 2:50:23 AM. Forum started by
George Mercier
1782
THE ESTIMATOR IN THIS PORTAL IS A VERY USEFUL TOOL WHICH CAN ENABLE A PERSON TO
Last answer on 7/7/2020 12:51:18 AM. by
K S SHYAM SUNDER
3648
Ghar Expert Estimator Tool questions
Last answer on 7/3/2009 1:11:00 AM. by
ksk
j smith
2958
Hi, I want to start the construction on my plot which is located in pune.the si
Last answer on 8/6/2009 1:22:19 AM. by
Priti Arora
vivek
1855
Hi, I have plot with size 26.6" (width) x 66" (length)(East to west) in katraj
Last answer on 1/20/2011 9:11:04 PM. Forum started by
abid_baig@yahoo.com
28820
latest price of building materials in bangalore
Last answer on 10/10/2010 12:44:43 PM. by
rudresh
manjuks
1643
HAI I HAVE PLOT AND I PLANNING TO CONTRUCTION SO INEED PLAN FROM U AND THE SITE
Last answer on 1/21/2013 11:40:18 AM. by
gangaraju
1277
Plaster of Paris
Last answer on 1/18/2017 2:14:19 PM. by
Karan
2184
Last answer on 1/29/2014 11:52:53 PM. by
gnyoganarasimhan
2975
Civil Work - Construction Estimate for Stilt + 2 Floors
Last answer on 11/11/2013 11:51:30 AM. by
Sujith
6705
What precautions should be taken while constructing leakproof Slab
Last answer on 5/9/2011 5:23:28 PM. by
Moreshwar Kelkar
tiwari_p_k
3075
RCC roof
Dinesh Bhadu
1970
Marriage hall construction
chandana kumar
2536
Function Hall
Last answer on 6/14/2021 7:48:53 AM. by
Janette
Mark Paraon
4200
Mohan Bhagwat
11102
Last answer on 3/16/2021 12:44:03 AM. by
Mohan
2189
Last answer on 11/19/2020 1:18:18 AM. by
Aamir
2037
Estimate
Last answer on 7/3/2020 10:09:08 PM. by
amzad
amzad
3071
Steel
Last answer on 7/2/2020 10:08:44 PM. by
EvaR
use of tmt bar
sonu.211
1641
work turned out by labour
Last answer on 5/15/2017 1:35:22 PM. by
carola braats
2456
estimate
raj
1761
mohd asif
2991
3605
Last answer on 5/26/2016 3:18:53 PM. by
naresh
1942
Cost of Steel construction
Last answer on 4/22/2016 11:27:17 AM. by
VikasUmate
1612
Last answer on 12/17/2015 2:49:59 PM. by
sushantsah
2135
READY MIX PLASTER
Bimlendra Jha
1864
Last answer on 3/1/2015 8:14:42 PM. by
baskar
2222
zero slump concrete
Malik Usman
Gardening Tools
Are you beginner in gardening and don’t know about gardening tools? To properly maintain your garden, you should have ..
Which tools are recommended for Terrazzo flooring?
Tools for Terrazzo Flooring--WOODEN MALLET:- Usually used to knock wooden pieces together, or to drive chisels into st..
The following tools are recommended for door, windows and ventilator frames:
Which tools are recommended for POP?
Finishing trowel: It is used for spreading and leveling plaster on the surface.
What are various tools used for the installation of Fluorescent tube light?
Fluorescent light tubes come in many shapes and sizes. An increasingly popular one is the compact fluorescent light bu..
