Home -> Forums -> Construction -> Bricks -> Cost of Brickwork
Cost of Brickwork
Mon Jun 07, 2010Total posts : 1
Abhijeet Shinde
Abhijeet Shinde
Topic: Cost of Brickwork
Hi ,
I have started construction of my Bungalow, RCC work will complete by June end. I want to know what will be cost of 6 inch brickwork and inside+outside dual coat plaster for carpet area of @2500 Sq. feet.
Tue Jun 08, 2010Post  #1
Dear Abhijeet Shinde
The quantity of brick work and plaster can be calculated with the help of the drawings of your bungalow. Also clarify about 6” thickness of brick works because in general clay brick size is 9”x 4.5”x 3” and thickness of walls are either 9” or 4.5”.
3941
1667
About the construction cost of my home
Last answer on 5/4/2016 1:36:52 PM. by JAI PRAKASH. Forum started by Rajendra Newaskar
2350
9" brickwork Compound wall length of 25ft and 7ft height with out beam / columns
Last answer on 8/21/2017 1:06:37 AM. by S L Gupta (Civil Engg). Forum started by Prakash
3495
Robo Sand for Brickwork
2799
what is the cost of living room forinterior designing and all the cost of rooms
Last answer on 7/3/2020 10:01:06 PM. by S L Gupta (Civil Engg). Forum started by priyanka
6099
What is construction cost
3977
Last answer on 7/3/2020 10:06:39 PM. by raghuam. Forum started by srihari
3845
comments required
Last answer on 11/18/2021 7:51:18 AM. by Gunjan Utraja. Forum started by gangula
2649
1981
HOW MUCH COST WILL BE 3 BHK IN 1500 SQUARE FEET, PLEASE GIVE DETAILWISE MATERIAL
Last answer on 12/9/2015 11:40:05 AM. by S L Gupta (Civil Engg). Forum started by manoj
2622
2746
2176
6880
1726
what is the cost and feasibility of installing a water softner for 4 members
Last answer on 10/16/2014 12:52:21 AM. by JAI PRAKASH. Forum started by neelam rathi
2185
nice looking & cost effective
Last answer on 1/23/2021 2:58:42 AM. Forum started by psatyajit46
2048
dear sir i have built a 26 by 34ft house tell me a total cost
Last answer on 10/16/2014 12:28:26 AM. by JAI PRAKASH. Forum started by nilesh disale
2018
COST DETAIL REQUIRED
Last answer on 12/24/2013 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by ANNA.B
2184
what is the cost of a shower enclosure made of toughened glass of 4x4 size
Last answer on 1/25/2021 8:51:09 AM. Forum started by neelam rathi
7513
Brick Advice Urgent
2879
Bricks
2794
brick calculation
4894
2821
2350
3172
bricks
5659
3238
5135
Use of Solid Concrete Bricks
1624
1341
1846
1480
1797
2966
fly ash bricks
2230
1723
