Home -> Forums -> Construction -> Cracks -> Cost for Polyurethene Grouting for Leakage from Flat Above
Sat Mar 14, 2015Total posts : 2
Unmesh
Unmesh
Topic: Cost for Polyurethene Grouting for Leakage from Flat Above
Water is dripping from the flat above. I have seen that Polyurethene Grouting can be done from the flat below. This would be permanent and slove the problems. Please advise the rate charged by the firms in Navi Mumbai.Regards
Thu Mar 26, 2015Post  #1
Post subject: cost for polyurethene grouting
         For rate of polyurethene grouting you can visit hardware shops of your area and ask them for rate .
Thanks.
Sat Mar 28, 2015Post  #2
It will cost you around 25-30 Rs/Sq.ft.
Cracks-Construction Questions (30)
1330
Need cost for the above mentioned doors
Last answer on 10/3/2016 1:49:57 PM. by S L Gupta (Civil Engg). Forum started by Aarti
1408
how much cost to above tipe of elivation
Last answer on 7/4/2020 2:24:17 AM. by S L Gupta (Civil Engg). Forum started by Rayapati Kowsalya
2746
2536
5359
2BHK FLAT - TWO PORTIONS - TWO FLOORS - 110 AQ YRDS
Last answer on 1/13/2014 2:21:22 PM. by S L Gupta (Civil Engg). Forum started by Hemant Tiwari
roofing on open terrace
1638
3370
2298
3123
2535
How to arrest leakages through expansion joints.
Last answer on 11/20/2009 10:16:24 AM. by Girish. Forum started by Jagadesh Babu
2275
Last answer on 9/25/2021 12:44:28 AM. Forum started by abid_baig@yahoo.com
3376
New House Construction
Last answer on 12/31/2020 2:45:48 AM. by srinivas reddy. Forum started by srinivas reddy
1816
layout floor plan
Last answer on 11/21/2013 9:57:53 AM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2239
How to avoid Heat in Top Floor
Last answer on 4/29/2014 11:15:27 AM. by S L Gupta (Civil Engg). Forum started by Aarif Eqbal
1553
Leakage question.There is leakage in the floor below my bathroom. From the apart
Last answer on 10/21/2014 11:39:49 AM. by S L Gupta (Civil Engg). Forum started by D.P.S
2914
Last answer on 1/5/2022 12:27:42 AM. Forum started by Vineet Sethiya
4765
2072
My flat is on the first floor facing to east in an apartment. The first floor is
Last answer on 3/3/2013 10:50:21 PM. by Pavan. Forum started by Ramesh Kapoor
3381
Recurring Cracks
4138
5734
1592
How to renovate the broken staircase. please look the attachments.
Last answer on 4/25/2016 1:08:43 PM. by S L Gupta (Civil Engg). Forum started by chitta naik
6881
2278
2296
cracks in walls
Last answer on 9/4/2013 12:14:18 PM. by S L Gupta (Civil Engg). Forum started by Gagandeep
2059
Cracks in my new house
3134
4035
2648
How To Repair Cracks
Last answer on 5/6/2010 12:31:22 AM. by . Forum started by suni dutt panwar
What preparations for base are recommended for terrazzo tiles flooring?
Preparation for base:- It is one of the most important steps to satisfy the tile installation. Sub flooring should be ..
Electric
Preventive
Swimming
Inground
Inground Swimming Pool
