Home -> Forums -> Construction -> Cement Concrete -> Cost of concrete walls
Wed Jul 18, 2012Total posts : 4
Ankur Kothari
Ankur Kothari
Topic: Cost of concrete walls
I am planning to construct the outer walls of my house as concrete walls. I want to know what will the approximate cost of the walls alone. Specification of the walls :
3 inch concrete wall
Length of concrete wall 200 feet
height of concrete wall 35 feet
I am going for a concrete wall to create space as well to ensure safety. A 4 inch brick wall will be weak as the outer walls of a house.
Kindly give your advice.
Wed Jul 18, 2012Post  #1
Dear Ankur
      You want cement concrete i.e. RCC wall 200'x35'x3'' =1750 cft and the rate per cft is RS 250-00 per cft which comes Rs 6 3 -00per sft. and M. S. steel cost is Rs 120-00 percft or Rs 30-00 per sft.
Thu Jul 19, 2012Post  #2
Ankur Kothari
Ankur Kothari
THANK YOU SIR
Fri Jul 20, 2012Post  #3
sam_m400
sam_m400
Post subject: Cost of concrete walls
Why measured in Cu:ft and Sq;ft ? Which rate we should take in finding the total calcuation?
I have seen some contractors saying foundation will be on Cub:ft , but some saying it is on Sq:ft .How do we judge which is on Cub;ft and which is on Sq:ft
Fri Jul 20, 2012Post  #4
Ar. Manoj Ralen
Ar. Manoj Ralen
Dear Sam,
All construction work has three dimensions which is length, breadth and height/depth so it makes sense to have these in cubic feet.  However for some of the work, where one dimension is standard you can measure that work in square feet. For example, if you are doing a brick work for 9inch wall then you can measure the wall area in square feet because the thickness has been fixed. It is a good practice to clearly understand all three dimensions while negotiating a price with the contractor.
Let me know if you need more information.
3086
9211
3849
2530
2154
4047
Cost Comparison Between Brick Wall & Concrete Frame Structure
Last answer on 7/3/2020 11:40:50 PM. by PR Jawahar. Forum started by PR Jawahar
3011
6477
2173
can you suggest me the probable cost for onw wall of approx 10.5 X 12 Feet
Last answer on 11/13/2016 12:56:53 AM. Forum started by Lokesh Gupta
2880
1784
HiI want to calculate Life Cycle Cost of normal ordinary concrete roof and brick
Last answer on 5/12/2015 2:38:18 AM. by JAI PRAKASH. Forum started by Saikat Sahu
2027
3462
1862
2415
COSTING AND STRENGTH OF WALL
1772
1464
1571
I would like to know where I can get the wall decor and how much it costs.
Last answer on 9/9/2011 10:50:08 PM. Forum started by Prakashrao
1800
STP
3112
3656
4351
rate comparison
3211
Concrete Mixture
3147
sloping roof
2095
15850
6477
2387
leakage in new slab
1534
Guide me
5150
2541
Civil Eng Stair Design
2541
2338
Related to Sunken Slab
1862
2002
Concrete Hollow Block Masonry
2424
roof concrete
3202
Ready Mix Concrete
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
Canvas
Canvas Wall Art
Wall
Wall Decor
