Green Building
Cost of construction - Less expensive?
Wed Oct 16, 2013
Prasad
Topic: Cost of construction - Less expensive?
I have been living in Australia and observing the constructions here. I am wondering what are the advantages and disadvantages in adopting this model in India. Usually the built up area would start from 2000 sq ft and goes until 3000 sq ft.
Here usually residential houses are single level. No RCC roof, no pillars and no beams. They do foundation and some steel is used in this. Structure is built using wooden framing. On this wooden frame they fix the roof with cement/clay tiles.
There is one layer of brick around the outer wall. Inner walls are made by attaching gypsum sheet to both sides of wooden frames. So, separating walls are made of wooden frame and gypsum sheets.
Steal, cement, sand used to a very minimum. Wood is used extensively. Dead weight is very low as there is no RCC roof and beams.
Why can't we use this model in India? Would this be cheaper as use of steal, cement and sand is very low and also very low labour intensive. Interiors look really amazing.
Please comment.
Wed Oct 16, 2013
Dear Prasad
As you stated the construction practice of Australia that the people construct single story house.
In India the population is on high side, there is scarcity of land for construction, land cost is very high. By this factor people construct multistory buildings. For designing and safety RCC slab is laid on roof.
As in India there is scarcity of wood and the quality of wood is inferior, cost of wood is very high also to maintain wood is costly in compare to brick walls. In multistory building wooden partition wall is not able to take roof load.
If you have enough land and want only single story house, than use the model which you see in Australia. This type of construction is economical and cheaper.
Green Building-Construction Questions (38)
1985
lets know the cost of brass doors apart from saying that they r expensive.....hw
Last answer on 6/28/2010 3:17:30 PM. by
Richa Shangvi Interior decorator
sonu
6099
What is construction cost
Last answer on 12/1/2020 5:38:30 AM. by
manoj
COST construction of only 1 story house and construction of G+4 residential cost is 1:5 or different
Last answer on 12/8/2014 8:24:49 AM. Forum started by
azad
2147
are iron doors expensive than pvc doors?
Last answer on 3/2/2014 5:40:13 PM. by
neelam rathi
premkumarlen
6464
Last answer on 6/25/2013 11:09:36 AM. by
kumar gautam
4807
Last answer on 7/9/2014 11:16:51 AM. by
nadim
2680
Last answer on 2/3/2022 10:54:35 PM. by
jahangir
2353
Last answer on 4/11/2013 11:08:41 AM. by
suresh
3384
what will be construction cost for a bunglaw at khandala, near lonavala
Last answer on 4/27/2016 3:10:29 PM. by
vaid
10178
Last answer on 7/4/2020 2:49:28 AM. by
Amarnath
1977
Supervision cost
Last answer on 10/5/2016 11:03:54 AM. by
kalpesh
2536
Last answer on 5/13/2019 1:18:38 AM. by
simran
1477
Last answer on 7/4/2020 3:05:49 AM. by
Mukesh dayani
1783
Last answer on 3/17/2021 12:53:46 PM. by
MD KAMIL RASHID
2745
Last answer on 12/27/2016 4:34:02 PM. by
sathis
23866
Last answer on 7/8/2020 10:27:10 AM. by
sonu
4703
How can we save money and less wasted through vastu tips at home
Last answer on 7/4/2020 2:01:06 AM. by
Deepti
shalini kulshreshtha
1809
how to make a good house within 8cent with less money
Last answer on 12/13/2010 2:08:04 PM. Forum started by
EARINDIAS
1833
roof farming
Last answer on 2/25/2022 4:26:25 AM. by
raj
3267
Last answer on 1/24/2022 9:52:50 PM. by
Akash Sharma
3179
Architect to Build Green Modern Home in Bangalore
Last answer on 11/21/2021 1:07:48 PM. by
fabions
rahulsharma
2914
Help with a documentary about sustainability
Last answer on 10/5/2021 8:27:02 AM. by
Chibi Moku
3021
hpl panels for exterior
Last answer on 8/26/2021 8:40:25 AM. by
HardissonHard
kamal
2876
estimation
Last answer on 2/19/2021 5:35:30 AM. by
Last answer on 7/4/2020 2:05:29 AM. Forum started by
Alisson Chan
2143
Marriage Palace & School Auditorium
Last answer on 7/3/2020 11:27:36 PM. by
Marinedeejay
1767
House plan
Last answer on 7/3/2020 11:15:18 PM. by
udaykumar mugali
3493
Last answer on 7/3/2020 9:53:22 PM. by
Modern Homes
1319
Is there any transparent sheets available for tress work on roof so as to cultivate on Terrance?
Last answer on 2/21/2017 12:33:33 PM. by
1679
Concrete Roof Insulation
Last answer on 6/25/2016 11:19:30 AM. by
Omar Chaudhry
1735
Solar energy integrated houses
Last answer on 7/6/2015 12:24:02 AM. by
Kumar
4196
Low cost housing option
Last answer on 8/11/2014 9:23:57 PM. by
Dinesh Sharma
2089
Low cost roofing solution over a slanting slab for internal cooling
Last answer on 12/1/2013 8:03:10 PM. by
Girish
Girish
2658
Last answer on 3/4/2013 12:25:11 PM. by
nasad
nasad
cost of construction of type G + 2
Last answer on 8/26/2012 4:08:55 PM. Forum started by
santhosh
2711
Chemtreat India
Last answer on 9/8/2011 3:05:20 PM. Forum started by
Chemtreat India
2266
interiors
Last answer on 7/15/2011 4:05:38 PM. Forum started by
keerthi
