Cost of construction of roof slab.
Sat Sep 07, 2013Total posts : 2
suhas
suhas
Topic: Cost of construction of roof slab.
Dear sir,
I am extending my balcony dimension 26' X 15' sq ft. with 6'' thickness with 3 columns of 12' height and 3 external beams of 15'ft.
12mm steel used in slab.
16mm steel used in columns and beam.
Can you please provide an estimation of material with/without labor charge.
Thanks,
Suhas Harbola
Mon Sep 09, 2013Post  #1
Dear Suhas
      You have not given the size of column and beam i.e.the width and thickness of beam and column with out this cost can not be calculated.
Fri Sep 13, 2013Post  #2
feroz khan patthan
feroz khan patthan
Post subject: Cost of Construction of Slab
Your Total area is 44 sq yards
If you use 9"x9" column and 9"x1' beam it will cost around 1.2 lakhs
Feroz
LIMC PVT LTD
4808
4649
2335
191902
9894
2559
2977
2033
2092
3754
1908
4953
3980
Roof leakage
6100
What is construction cost
2867
8421
Roof Beam crack
42599
Labour Cost for Roof RCC work
26
32
Iron
Iron Sheet Roofing
Cooper
