Home -> Forums -> Construction -> Start Construction -> Cost of construction
Fri May 09, 2014Total posts : 1
awdhesh
awdhesh
Topic: Cost of construction
What is the cost of construction per sq fit in Bangalore. ?
And what is the cost of construction per sq ft for stilt parking ?
What would be the cost of construction of foundation for 31 by 34 plot for Stilt +1+2+3?  (approximation)
Thanks in advance
Sat May 10, 2014Post  #1
       The cost of construction depend or related with the plan, elevation, structure and specification used in the construction.  Cost related with so many factors nos of windows, door railing, columns etc. The hit and trial method proves costly in long run.
 For better option have detail estimate, which willgive you rate,cost per item, quantity of material required according to drawing and specification.As you stated foundation cost for 31x34 sft area. There may be 2,wall or 3 walls as per plan design so cost is variable, cost range from Rs 1100-00 to 2000-00 as per drawing, design and specification.
 For more information see the link below.
http://www.gharexpert.com/articles/Start-Construction-1528/Guidelines-while-Starting-Construction_0.aspx
http://www.gharexpert.com/construction-ideas/start-construction.aspx
http://www.gharexpert.com/articles/Start-Construction-1973/Gharexpert-can-save-you-money-during-construction_0.aspx
3384
what will be construction cost for a bunglaw at khandala, near lonavala
Last answer on 4/27/2016 3:10:29 PM. by S L Gupta (Civil Engg). Forum started by vaid
1477
23866
2354
what would be the cost of construction for this kind of house for approx floor o
Last answer on 8/21/2010 12:50:17 PM. by S L Gupta (Civil Engg). Forum started by bhavin
3542
Contruction Tool
2745
Constractor cost in chennai(Pallavaram)?
Last answer on 9/11/2013 7:36:05 PM. by laddergrip. Forum started by Manzoor
2489
Approx.cost of construction from plinth area to completion of plastering for a12
Last answer on 12/23/2013 12:45:58 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
8581
Last answer on 12/25/2013 2:07:19 PM. by S L Gupta (Civil Engg). Forum started by arunkrishna kannambadi
2706
2563
Last answer on 3/2/2015 12:09:44 PM. by seema tyagi. Forum started by Alok
3802
22 x 63 size plot construction.
Last answer on 7/16/2015 10:39:22 PM. by JAI PRAKASH. Forum started by rajkumar pola
2267
Dear Sir
Last answer on 3/9/2013 11:21:57 AM. by S L Gupta (Civil Engg). Forum started by Sreenivas Kumar
3559
Last answer on 3/19/2013 11:44:19 AM. by S L Gupta (Civil Engg). Forum started by saurabh ramya
2335
cost of construction of house
Last answer on 1/13/2014 2:06:06 PM. by S L Gupta (Civil Engg). Forum started by j.B.Singh
2650
Cost of construction of roof slab.
Last answer on 9/13/2013 11:42:05 AM. by feroz khan patthan. Forum started by suhas
2123
Cost of Construction
Last answer on 8/19/2013 11:11:40 AM. by S L Gupta (Civil Engg). Forum started by Naveed Mohamed
1827
Cost of construction - Less expensive?
Last answer on 10/16/2013 12:53:12 PM. by S L Gupta (Civil Engg). Forum started by Prasad
1621
Last answer on 11/5/2013 10:32:59 AM. by S L Gupta (Civil Engg). Forum started by Ali
3947
Cost of construction of RCC Piller with Foundation
Last answer on 4/22/2014 11:15:43 AM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
3309
2133
2059
