Home -> Forums -> Construction -> Start Construction -> Cost of construction
Mon Nov 04, 2013Total posts : 1
Ali
Ali
Topic: Cost of construction
We own a land in Bangalore (City Center) and the size is 60 (width road) and 50 (depth) which makes it 3000 Sq ft. We plan to build apartments and rent it out.
Please share house plan and cost for Ground+2 floors. We plan for 1 flat on ground floor (for us) and balance 2 floors with 3 flats each.
Also on Ground floor we want car parking for tenants. So on Ground floor we need only 3 bedrooms.
Please provide plans and cost estimate.
Ali
Tue Nov 05, 2013Post  #1
Dear Mr.Ali
FOR PLAN
   FOR ESTIMATE
For tentative/ rough cost use estimator  at gharexpert.com at the link below
http://www.gharexpert.com/Estimator/Startpage.aspx
  If you want detail estimate then go to estimator for which link below
3384
what will be construction cost for a bunglaw at khandala, near lonavala
Last answer on 4/27/2016 3:10:29 PM. by S L Gupta (Civil Engg). Forum started by vaid
1479
23866
2354
what would be the cost of construction for this kind of house for approx floor o
Last answer on 8/21/2010 12:50:17 PM. by S L Gupta (Civil Engg). Forum started by bhavin
3542
Contruction Tool
2746
Constractor cost in chennai(Pallavaram)?
Last answer on 9/11/2013 7:36:05 PM. by laddergrip. Forum started by Manzoor
2489
Approx.cost of construction from plinth area to completion of plastering for a12
Last answer on 12/23/2013 12:45:58 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
8582
Last answer on 12/25/2013 2:07:19 PM. by S L Gupta (Civil Engg). Forum started by arunkrishna kannambadi
2708
2564
Last answer on 3/2/2015 12:09:44 PM. by seema tyagi. Forum started by Alok
3802
22 x 63 size plot construction.
Last answer on 7/16/2015 10:39:22 PM. by JAI PRAKASH. Forum started by rajkumar pola
2742
Last answer on 5/10/2014 1:21:28 PM. by S L Gupta (Civil Engg). Forum started by awdhesh
2268
Dear Sir
Last answer on 3/9/2013 11:21:57 AM. by S L Gupta (Civil Engg). Forum started by Sreenivas Kumar
3560
Last answer on 3/19/2013 11:44:19 AM. by S L Gupta (Civil Engg). Forum started by saurabh ramya
3781
cost for construction for a new home
Last answer on 1/10/2013 4:08:03 PM. by sapan. Forum started by sapan
cost of construction of type G + 2
Last answer on 8/26/2012 4:08:55 PM. Forum started by santhosh
3075
Qn regarding Cost Of construction
Last answer on 12/31/2020 2:00:00 AM. by S L Gupta (Civil Engg). Forum started by Ashwin Pai
2942
Cost of Construction
Last answer on 3/5/2011 2:23:12 PM. by Mohini Sharma. Forum started by Amit
3949
Cost of construction of RCC Piller with Foundation
Last answer on 4/22/2014 11:15:43 AM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
28624
Cost of Construction of boundary wall for vacant plot
Last answer on 7/23/2014 3:21:27 PM. by MANJUNATH. Forum started by Tejpal Singh
3310
