Home -> Forums -> Construction -> Start Construction -> Cost reduction
Cost reduction
Sun Sep 21, 2014Total posts : 1
sanu kumar
sanu kumar
Topic: Cost reduction
I am planning to construct a new two story hose with an area of 800 sq feet ground floor and 300 sq.ft first floor. It will be helpful to me, if you could suggest the ways/tips from the beginning to final of the construction to reduce the construction cost of house
Mon Sep 22, 2014Post  #1
Unoara Design Hub
Unoara Design Hub
In construction, the major expense comes from the materials which are used the maximum and in most modern construction, Concrete, Steel & Glass are main contributors to that.
You should consult an Architect and a structural designer to design or suggest the structure of your house, so that you do not spend on more than it is required, because most house owners, think that by putting in more steel they get a safer house, but in reality, there is something called as a safety barrier while designing a house, and once that is reached, it does not matter how much you add.
If you really have the time and patience, then 'Soil Compressed bricks' or fly ash bricks or even precast house modules could bring down your overall cost. Please share more details if you need detailed suggestion.
All the best!
Unoara Design Hub
1979
Last answer on 10/13/2016 11:06:46 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
20667
Heat reduction in the top floors
Last answer on 3/15/2011 10:12:45 PM. by Rohan Jaacob. Forum started by Dr. Tiwari
2799
what is the cost of living room forinterior designing and all the cost of rooms
Last answer on 7/3/2020 10:01:06 PM. by S L Gupta (Civil Engg). Forum started by priyanka
6099
What is construction cost
1314
Economical and reliable choice of type of exterior staircase to the rented 1st floor of house.
Last answer on 12/26/2016 1:12:50 PM. by S L Gupta (Civil Engg). Forum started by vinu
2745
2622
2649
1980
HOW MUCH COST WILL BE 3 BHK IN 1500 SQUARE FEET, PLEASE GIVE DETAILWISE MATERIAL
Last answer on 12/9/2015 11:40:05 AM. by S L Gupta (Civil Engg). Forum started by manoj
3977
Last answer on 7/3/2020 10:06:39 PM. by raghuam. Forum started by srihari
3845
comments required
Last answer on 11/18/2021 7:51:18 AM. by Gunjan Utraja. Forum started by gangula
2260
m15 cost vs m20 cost
2175
1407
how much cost to above tipe of elivation
Last answer on 7/4/2020 2:24:17 AM. by S L Gupta (Civil Engg). Forum started by Rayapati Kowsalya
1477
1006
Shuttering and labour cost 1600sft
Last answer on 7/3/2020 11:13:46 PM. by S L Gupta (Civil Engg). Forum started by Sri
2788
1759
1406
sir, what is the costing of tandur stone?
Last answer on 4/2/2017 7:48:45 PM. Forum started by gautam
3310
