Home -> Forums -> Construction -> Start Construction -> Costruction of different ground and first floor plan
Mon Nov 14, 2011Total posts : 5
Aamir
Aamir
Topic: Costruction of different ground and first floor plan
I intentd to construct my two storey house. The porblem is the first floor plan is different than ground floor plan. It implies the first floor does not have the same walls to be extended upward. What is the solution laying beams and Colums.
Tue Nov 15, 2011Post  #1
Dear Aamir
      It is better to take the suggestion of any civil engineer or structural engineer, who guide you after visiting the site of your house.
Tue Nov 15, 2011Post  #2
Aamir
Aamir
Thanks Sir I surely ill do that. But for the time being I just wanted to know whether is it possible or ele
Tue Nov 15, 2011Post  #3
Dear Amir
       As you want to know it is possible or not. It is possible with tecnical help.If you want help from gharexpert than send both plan to support@gharexpert.com.
Sat Nov 19, 2011Post  #4
pradeepbagga
pradeepbagga
Post subject: Possible
IT IS POSSIBLE AS THE BRICKWORK OF THE FIRST FLOOR IS OF FOUR AND A HALF INCHES AND THERE WILL BE NO PROBLEM ,IF REQUIRED U CAN USE STEP-UP COLUMNS IN FIRST FLOOR.
Mon Jul 09, 2012Post  #5
Ar. Manoj Ralen
Ar. Manoj Ralen
Dear Aamir,
As pradeep rightly said, it is possible to have different wall layouts on the first floor.  If you are constructing the building from start, your structure engineer would give you beam layouts for the roof that would be able to carry the load of walls. Also 4 and a half inches  non-load bearing partition walls can be constructed to give partitions between rooms.
It is recommended that the bathrooms should be kept above bathrooms so that the cost of the pipes would be reduced.
2069
1422
want to see ground and first floor plan of it
Last answer on 6/28/2016 2:34:13 PM. by S L Gupta (Civil Engg). Forum started by s k tiwari
3668
24feetby 81feet house plan ground floor ,dabal parking, one shop.
Last answer on 7/3/2020 11:24:29 PM. by S L Gupta (Civil Engg). Forum started by Pramod kumar
Last answer on 11/15/2016 2:10:38 AM. Forum started by K Srinivasan
9970
Last answer on 11/15/2016 1:51:43 AM. Forum started by K Srinivasan
1547
dear sir,i saw website can u help me to design my house plan..east faceing with
Last answer on 8/3/2016 12:24:24 PM. by Beenu Phogat. Forum started by anil
3237
3135
2742
2484
1916
Conceeled beams
Last answer on 7/3/2015 3:22:01 AM. by JAI PRAKASH. Forum started by manjula
1777
15654
1930
1694
sir i want a plan ground commercial and first floor double bedroom in east to we
Last answer on 3/5/2016 10:16:37 PM. by JAI PRAKASH. Forum started by joshi
COST construction of only 1 story house and construction of G+4 residential cost is 1:5 or different
Last answer on 12/8/2014 8:24:49 AM. Forum started by azad
2256
FRENCH DOOR IN GROUND FLOOR
Last answer on 2/11/2021 6:14:14 AM. by JAI PRAKASH. Forum started by sairam
2327
2480
3305
3320
4449
4020
2246
2724
4233
5205
2394
2320
2024
2463
2141
3214
2073
12543
2187
2029
2748
Preliminary
Appropriate
Terrazzo
Pool Pumps
