Home -> Forums -> Construction -> Cement -> Cracks in concrete roof
Tue Jun 28, 2016Total posts : 2
Aarav Sharma
Aarav Sharma
Topic: Cracks in concrete roof
I have noticed small cracks developing on my concrete roof. I would like to fix the problem myself since the cracks are still small in size and are just developing. I wanted advice on an effective and easy to use waterproofing compound that could fill the cracks and also prevent leakage during the monsoon. Any suggestions?
Wed Jun 29, 2016Post  #1
Dear Sharma
Repair Cracks on RCC Surface
Clean cracked portion and apply guniting
The cracked portion should be widen gently and be cleaned of all loose materials.  Fill the cracked portion by pressure grouting or ‘guniting’. The material for such grouting can be epoxy or cement (with suitable admixture).
Apply epoxy and finish the surface
Epoxy has more strength and adhesion than cement and can go into very thin cracks as fine as 0.1 mm. The surface should be finished according to adjacent area on the wall.
Note: The cracks in RCC members/ structural members should be repaired immediately with consultation form structural engineer/professional
Wed Aug 24, 2016Post  #2
Dhanush Ahuja
Dhanush Ahuja
Post subject: Finally found a solution!
Hi Aarav
I carried out waterproofing repairs on my concrete roof before the last monsoons. I had faced some leakages so I decided to call in a contractor to get the job done. He used a flexible waterproof coating that not only worked well that monsoon but is still going strong! I was very impressed with his work so I asked him what he used. He used a waterproofing compound called roff hyguard. I could see first-hand how effective it was so it definitely could be something that you could try.
2502
8419
Roof Beam crack
2414
roof concrete
2413
2106
2063
Minor crack in the roof concrete
Last answer on 9/22/2015 12:41:33 AM. by JAI PRAKASH. Forum started by bala
3271
Roof Concrete Strength
3133
1699
My House is 10 years old and my Existing Concrete roof in Hall area started to p
Last answer on 4/5/2018 12:46:08 AM. by S L Gupta (Civil Engg). Forum started by soundar
1066
2027
1709
Driveway Reconcreting
Last answer on 1/23/2016 8:41:13 PM. by JAI PRAKASH. Forum started by gpeter
3456
3142
sloping roof
11246
CURING ON ROOF CONCRETE
Last answer on 3/19/2014 10:26:34 AM. by Ahmed. Forum started by K Umapathi
2211
Roofing cost for 3000 sqft 2nd floor roof
Last answer on 6/17/2015 6:56:38 AM. by JAI PRAKASH. Forum started by sira
9195
2829
Dear friends In RCC roof of my home, there are cracks visible in soffit of slab
Last answer on 10/31/2010 1:50:03 PM. by RAKESH. Forum started by sunilrathi86
1669
Cement requirement
1784
RAW MATERIAL
3442
Type of Cement
2527
RCC Slab -Curing
2325
Materials
23818
Last answer on 2/17/2021 4:49:34 AM. by S L Gupta (Civil Engg). Forum started by vinu
2872
Types of Cement
2515
Cement
2735
Per Square
Last answer on 6/23/2019 11:56:29 PM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1282
1241
Last answer on 5/26/2016 12:44:58 PM. Forum started by SUNIL KUMAR
1741
2264
Cement selection
1876
Economical cement brand
Last answer on 2/22/2015 7:02:19 PM. by Bhuwan. Forum started by Bhuwan
2903
Cost of Cement Plaster
1856
Last answer on 4/11/2014 2:04:43 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
2484
Cement and Grades
Last answer on 6/13/2013 2:45:08 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
3040
2435
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by ravi at Dalmia. Forum started by Hemanth
How To Repair Cracks
Cooper
