Home -> Forums -> Construction -> Finishing -> Cracks on the walls
Cracks on the walls
Thu Jan 21, 2010Total posts : 1
devjani roy kashyap
devjani roy kashyap
Topic: Cracks on the walls
hi everybody,
I have a query and want to know if its ok to fill the cracks on the wall near doors and window frame with POP or shall that be filled with cement n then pop should be done?? the house is 4 year old and is on the top floor.
kindly oblige me your expert openions.. thank you
devjani Roy Kashyap
Wed Jan 27, 2010Post  #1
Post subject: Reply- Cracks on the walls
Dear Devjani,
Here is the answer for your query:
Remove the defective plaster around the cracks, clean the crack area with wire brush or broom. Fill the cracks with cement mortar and does plaster which was removed. Finish the area with POP after proper curing. You can take the help from the an article on website http://www.gharexpert.com, link given below.
http://www.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1371
S.L.Gupta
Finishing-Construction Questions (37)
2734
2344
3383
Recurring Cracks
4142
2900
2342
2507
2720
White stains in the walls and cracks in the walls
Last answer on 2/23/2011 9:05:33 PM. by Muralidhar. Forum started by Muralidhar
3000
2713
constraction details
Last answer on 1/1/2021 2:45:02 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
2930
2583
Looking for Precast Engineers, Precast Compound Wall and Precast Slabs
Last answer on 5/12/2014 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by nell
2489
Exterior Wall Crack Repair
Last answer on 12/26/2011 7:13:39 PM. by S L Gupta (Civil Engg). Forum started by S. Kumar
2708
How to fix cracks in my home
Last answer on 7/3/2012 12:04:18 AM. by Swati Satija. Forum started by vivek
3394
1910
Last answer on 5/21/2013 8:56:40 AM. Forum started by Aji
2297
cracks in walls
Last answer on 9/4/2013 12:14:18 PM. by S L Gupta (Civil Engg). Forum started by Gagandeep
2504
Reg: Cracks in cement brick walls
Last answer on 12/17/2013 12:32:00 PM. by S L Gupta (Civil Engg). Forum started by Dhananjay
2023
Last answer on 2/2/2022 11:26:31 PM. Forum started by manjunath
2599
Elevations Required
Last answer on 2/2/2022 10:53:23 PM. Forum started by gangula
2900
Wall painting
2087
CEMENT PANI - Plaster Works
1956
Triangle House roof
Last answer on 1/14/2022 4:58:49 AM. by S L Gupta (Civil Engg). Forum started by tayyab
3875
Last answer on 1/14/2022 4:09:54 AM. by S L Gupta (Civil Engg). Forum started by Sameer
2338
tiles or marble
Last answer on 12/4/2021 5:12:27 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3541
stone wall cladding
1519
help
1543
POP OR GYPSUM
10946
Lappam vs Wall Putty
1935
Last answer on 3/5/2016 9:18:00 PM. by JAI PRAKASH. Forum started by raj
1837
1964
1886
Final Handover
Last answer on 5/14/2014 2:15:33 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
2120
2573
Thermal Insulation of Home
Last answer on 3/29/2010 7:23:40 AM. by abhijeet pawar. Forum started by akkulshrestha
How To Repair Cracks
Which type of wall plastering is recommended for protection from the cracks?
To avoid cracks, Earthen Plastering is applied. Clay in Earthen Plasters is Hygroscopic (water absorbing). Earthen wal..
Surface
Canvas
Canvas Wall Art
