Home -> Forums -> Construction -> Brick work -> Curing for Brick Walls before and after Plastering
Tue Jun 14, 2011Total posts : 3
Sambasiva Rao Ravuri
Topic: Curing for Brick Walls before and after Plastering
Am seeing so many people that they are trying to do curing as much as possible. Am just curious to know about effectiveness of curing. Once Brick work is completed, let me know how many days we need to do curing with water and as well as once Plastering is done for Brick work how many days we need to do curing with water.
Please help me by answering this question and thanks a lot in advance for your help.
S Ravuri.
Wed Jun 15, 2011Post  #1
Dear Rao
 For brick work curing should be commence within 12 hours in case of cement sand mortar and continue at least minimum for 7 days but in case of rich mortar 1:4 and more curing should be done for 10 days.
For cement plaster curing should be started 24 hours after finishing and kept wet for 7 days . for more information about construction you should visit website gharexpert.com where lot of material are available about construction.
Sat Sep 21, 2013Post  #2
raj
raj
Curing of plastering
Mon Sep 23, 2013Post  #3
Dear Raj
    For cement plaster curing should be started 24 hours after finishing and  do curing  for 7 days and kept wet for 7+8= 15 days. . for more information about construction you should visit website gharexpert.com where lot of material are available about construction.
http://www.gharexpert.com/articles/Cement-Plastering-1037/Achieve-a-good-quality-in-%E2%80%98Plastering%E2%80%99_0.aspx
5008
3079
How much time curing is required for bricks wall.
Last answer on 6/17/2016 12:45:17 PM. by S L Gupta (Civil Engg). Forum started by MANISH
3669
wals
2523
35211
2782
Plaster work
4629
time for paint and wall putty
2422
2925
7006
2095
Red Exposed Brick
Last answer on 12/8/2014 10:03:59 PM. by JAI PRAKASH. Forum started by awdhesh
8880
3992
3968
water proofing of water tank
3476
labour charges rates
2521
construction const
2417
2364
Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Last answer on 7/9/2012 3:21:23 PM. by Ar. Manoj Ralen. Forum started by Lynda
2212
Painting interior walls
3669
wals
3264
compound wall
21875
3280
Bedroom Wardrobes information
2246
2206
1494
1965
1732
2224
2523
1502
1910
Brick or ACC block
1654
2153
1702
4688
Brick wall on RCC slab
3929
2618
Plastering
Plastering
Checklist for Cement Plaster
Gypsum
