Home -> Forums -> Construction -> Start Construction -> D.P.C.-DEMP PROF COURSE
Tue May 17, 2016Total posts : 1
Topic: D.P.C.-DEMP PROF COURSE
what is the d.p.c. and why it is required? which materials are used in d.p.c. and where d.p.c. is used?
Wed May 18, 2016Post  #1
Dear Ankita
Guideline for laying DPC
One of the essential requirements of building is that its interior should remain dry. A damp building is unhealthy and causes damage to the structure. There are many causes of dampness in the building such as due to defective design, substandard building material, improper execution and rise of dampness from foundation.  So it is most important and necessary to provide Damp Proof course (DPC) in the building at the time of construction.
As the foundation of all the buildings are embedded in the soil. As bricks being porous and which are generally used in foundation below ground level can absorb moisture from adjacent ground or soil. The moisture travels up from one course to another by capillary action and can make the wall damp for a considerable height. Rise in ground water table in the rainy season may aid the entry of moisture in to the wall and in the floor.
To prevent water absorbed from the soil rising and causing dampness in the wall and adjacent wood work and plaster, a continuous layer of an impervious material is provided. This layer is known as horizontal damp-proof course (DPC). The damp-proof course should be laid at plinth level i.e. at floor level in all building except temporary structures. The plinth level of the building should 45cm above the ground. On the outer walls the DPC is laid at the ground level, to save wall from dampness of floor, vertical DPC is laid on the outer walls on internal surface from ground to plinth level.
The thickness of horizontal DPC for boundary wall is 25mm and for building is 40mm or 50mm. The DPC is consists of cement concrete 1;2;4 i.e. 1 is cement, 2iscoarse sand and 4 is stone aggregate or BAZRI. The DPC should in full width of wall and should not be set back from the face of wall for pointing. It must be continuous for the whole length of the building. There should be no any construction joints in the damp-proof course. The DPC is not carried across doorways and openings.
DPC laying guide line
  • Before laying the DPC the surface of brick or stone masonry should be in level.
  • See that the edge of DPC should be straight, even and vertical.
  • The side shuttering should consist of steel form.
  • Ensure that the side shuttering is strong enough so that does not get disturbed while laying and compacting the concrete mix.
  • The side shuttering should be tight so that mortar/ concrete mix should not leak from the side.
  • The cement concrete mix ratio should be 1;2;4 and see that all the gradients such as cement, fine aggregate, coarse aggregate and water should be according to specification.
  • The cement concrete mix should be of workable consistency and should be tamped thoroughly to make a dense mass.
  • See that the side surface should be smooth without honeycombing.
  • The DPC should be cure for 7 days after which it should be allowed to dry for at least one day before application of bitumen.
  • Before application of bitumen, the dried surface of DPC is cleaned with brushes and finally with a piece of cloth soaked in kerosene oil before application of hot bitumen.
Apply the hot bitumen in two coats uniformly at the rate of 1.7 kg per square meter all over, so that no blank spaces are left anywhere on the DPC.
20123
1860
Last answer on 12/24/2015 4:06:01 AM. by JAI PRAKASH. Forum started by sushantsah
2090
Foundation
1633
GROUND WORK
Last answer on 9/23/2015 6:37:57 PM. by JAI PRAKASH. Forum started by sumit
2081
help
Last answer on 1/9/2015 12:09:16 AM. by JAI PRAKASH. Forum started by Asif
3143
course interiordecoration
2903
I am very appreciated for downloading your interior home design and hope that it
Last answer on 7/3/2020 11:27:09 PM. Forum started by Asraf Mallik
6306
terrace flooring
Last answer on 7/3/2020 10:25:00 PM. by JAI PRAKASH. Forum started by Radhika
4995
Weathering course
Last answer on 7/25/2014 9:42:13 PM. by JAI PRAKASH. Forum started by Radhika
1851
DPC
Last answer on 7/3/2020 11:21:47 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
1680
earthquake safe building
Last answer on 5/12/2015 2:55:33 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
1514
I am constructing a house in Dharamsala ( place having second highest rain falll
Last answer on 12/21/2015 1:41:44 PM. by Bhupinder Kumar. Forum started by Bhupinder Kumar
1755
2673
why bath room with toilet cannot be built as per vasthu...of course pooja room k
Last answer on 10/9/2020 5:48:28 AM. by Nikita. Forum started by D.Ramachandran
2508
Query reqarding Foundation & Tie Beam
Last answer on 1/10/2015 12:32:04 PM. by S L Gupta (Civil Engg). Forum started by Gian Prakash
2108
foundation
Last answer on 7/3/2020 11:10:18 PM. by S L Gupta (Civil Engg). Forum started by nazeersyed
2542
layout and planplan
Last answer on 4/21/2015 2:30:45 AM. by JAI PRAKASH. Forum started by abhijeet joshi
2399
2587
mortar thickness in brick joints in foundation
Last answer on 8/23/2011 8:47:15 PM. by S L Gupta (Civil Engg). Forum started by ahsan
3310
2133
2059
Which type of Damp Proof Course (DPC) is recommended for protection from cracks ?
The best DPC is of plastic membrane placed across the whole width of the wall to its full length
Damp
Damp Proofing
Which type of DPC recommended for the protection of dampness?
For residential buildings DPC consists of a layer of - 40 mm thick cement concrete 1:2:4 (1 cement: 2 Coarse sand: 4 g..
