Home -> Forums -> Construction -> Dampness -> Damp Proofing
Damp Proofing
Sat Jun 06, 2009Total posts : 5
VIPIN
VIPIN
Topic: Damp Proofing
Initially I have used Dr. fixit for seapage in manhole. Now after 4Yr. there again seapage started in both drain water and flash pipes. Is there is any permanent remedy for that. Thanks.
The comment above talks about the article   "Damp Proofing "
Mon Jun 08, 2009Post  #1
H S Rathi
H S Rathi
Post subject: Damp Proofing for Seepage
For permanent remedy, fix new flash pipe with proper joint. Repair the defective portion of drain by scraping old plaster, and render the new plaster properly.
Mon Jun 08, 2009Post  #2
Dear Mr. Vipin,
Can you please upload the pictures of the affected area so that we could judge the damage extent?
Thx
Mon Aug 01, 2011Post  #3
sunil
sunil
Some walls in my house become damp in rainy season, proberbly because of rise in ground water level.Dampness is about 5ft high. What should I do? Is there any permanent solution for it?
Thu Apr 04, 2013Post  #4
subramaniam
subramaniam
We have a water sump which was re plastered using mesh .After two years it started seepage.You are requested to advise me how I can overcome this problem of seepage.
Mon Jun 22, 2015Post  #5
Mike Perkin
Mike Perkin
All the epoxy, acrylic, bitumen, flexible rubber, special cement products listed dont work against Rising Dampness because the salts destroy the cement from inside the wall The only permanent solution to Rising dampness is by physically injecting a DPC above the floor level.I have developed a fast reacting DPC Silicone that after 3 days makes a dry brick 100% water repellent, unlike the other UK Silicones that need 6 weeks and rain to activate.In other words you can inject my product into the wall and youll be protected before the Monsoon arrives! This product is distributed in Mexico and im looking for business partners in India,contact Civil Engineer Mike for more details antisalitre@aol.com
Dampness-Construction Questions (35)
2144
i need the term related with damp proof and its treatment
Last answer on 8/29/2012 5:01:18 PM. by S L Gupta (Civil Engg). Forum started by abhijeet joshi
1958
2767
1885
Damp
Last answer on 4/4/2015 7:00:17 PM. by JAI PRAKASH. Forum started by Jag
2076
Hi I am looking for an expert to get rid of damp in my house in Punjab india.
Last answer on 4/25/2015 2:20:07 AM. by JAI PRAKASH. Forum started by Jag
2232
2068
Last answer on 4/6/2016 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by zakia sultana
2236
What are requirements of drainage and sanitation for dwelling area covered with individual?
Last answer on 6/20/2013 5:14:02 PM. by Sandip Kar. Forum started by g.s.rajan
2033
in vasthu how to find members of a familywhere r the 1st 2nd 3rd...like that chi
Last answer on 3/28/2011 8:28:05 PM. by Swati Sharma. Forum started by D.Ramachandran
3828
ROOF WATER PROOFING / TANKING
1736
best reliable & surge proof l ed light fittings for indian homes
Last answer on 9/22/2013 1:50:16 PM. Forum started by sanjeev tiwari
1849
Last answer on 11/29/2011 10:51:56 AM. by harshu. Forum started by barun chatterjee
2341
lift pit water proofing
1871
SOUND PROOF MATERIAL FOR CEILING IN FACTORY
Last answer on 2/7/2013 6:03:59 PM. Forum started by saif
2105
I have a 1650sq ft flat which I am renovating What company/material I use for a
Last answer on 4/14/2013 3:03:56 PM. Forum started by capt vngautam
2115
Structure proof checking
2896
Terrace water proofing
1698
Cool proof tiles
Last answer on 5/19/2016 12:31:25 PM. by S L Gupta (Civil Engg). Forum started by Rajendran
3490
How to solve dampness in wall
Last answer on 11/17/2016 10:58:15 AM. by Girish. Forum started by Rajan
1861
Last answer on 12/24/2015 4:06:01 AM. by JAI PRAKASH. Forum started by sushantsah
1491
Canada Goose Chilliwack Bomber much likewise
Last answer on 11/14/2015 12:37:51 AM. by JAI PRAKASH. Forum started by farofaschafer
2073
2106
2131
Walls are damp in rain
2084
1885
Damp
1920
Leaking Ceiling
Last answer on 8/25/2014 8:26:28 PM. by JAI PRAKASH. Forum started by sandipvora
2762
1926
bathroom dampness
Last answer on 12/23/2013 12:21:54 PM. by S L Gupta (Civil Engg). Forum started by sunder
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2531
Reasons of dampness
2366
water treatment for walls
Last answer on 4/27/2011 7:37:34 PM. by S L Gupta (Civil Engg). Forum started by gajender pathak
1749
2086
Last answer on 4/12/2010 8:36:47 PM. by haritha. Forum started by sujani
Damp
Damp Proofing
Protect
Guideline for laying DPC
Which type of Damp Proof Course (DPC) is recommended for protection from cracks ?
The best DPC is of plastic membrane placed across the whole width of the wall to its full length
Fire
Earthquake
Electric
Electric Shock Proof Home
