Dear Sir,What is the concrete grade used(M15/M20 etc.) in roof casting of normal
Thu Jun 02, 2016Total posts : 1
pal
pal
Topic: Dear Sir,What is the concrete grade used(M15/M20 etc.) in roof casting of normal
Dear Sir,What is the concrete grade used(M15/M20 etc.) in roof casting of normal two storeyed house?
Fri Jun 03, 2016Post  #1
Dear Pal
         Concrete grade M15 is the cement concrete ratio/ mix= 1:2:4.
         Concrete grade M20 is the cement concrete ratio/ mix= 1:1.5:3.
It is advisable use M20.
3273
Roof Concrete Strength
1781
2496
Used M15 (1:2:4) mix ratio with PPC cement for casting ground floor house roof slab
Last answer on 2/21/2017 12:28:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
2693
Want to know the Strength of the Roof Slab
Last answer on 3/8/2011 5:41:21 PM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
32561
Cost of RCC Pillar
2539
2260
m15 cost vs m20 cost
191902
1908
856
Kindly refer my attachment,For G 2 residential building, M15 grade used ,for roo
Last answer on 7/4/2020 2:29:32 AM. by S L Gupta (Civil Engg). Forum started by Sathya
929
Last answer on 7/2/2020 9:41:30 PM. by S L Gupta (Civil Engg). Forum started by Sathya
8421
Roof Beam crack
2697
2568
1649
concrete grade
Last answer on 12/24/2015 4:21:52 AM. by JAI PRAKASH. Forum started by Rohit Sharma
1403
3748
How to cast sloped/slanted roof, as our architect described inablity to use vibr
Last answer on 3/5/2013 12:11:16 PM. by S L Gupta (Civil Engg). Forum started by mrityunjay singh
2677
17
15
26
32
Types of Cement
Skylight
Hard
