Home -> Forums -> Interior -> Dining room -> Dear friends In RCC roof of my home, there are cracks visible in soffit of slab
Sun Oct 31, 2010Total posts : 2
sunilrathi86
sunilrathi86
Topic: Dear friends In RCC roof of my home, there are cracks visible in soffit of slab
Dear friends In RCC roof of my home, there are cracks visible in soffit of slab almost in all rooms which are 12'x13'and 12'x14'.There are no beams. The cracks are diagonally approaching from center of slab towards walls. Construction is 4-5 years old. I want to strenthen slab by putting ISMB under soffit of slab but its appearance may not be pleasant. May I know from Forum to guide me to follow correct procedure to strenthen slab. can I construct first floor after this process. please express your veiws. thanks Sunil Rathi
Wed Nov 03, 2010Post  #1
Dear sunil rathi
            There are so many causes of cracks in the slab such as less reinforcement used in the RCC slab, deffective or under specification materials, less curing, salty water and deffective laying i.e.poor workmanship. From the contents of sent by you, you should contact any structural engineer who can give abetter reamedy after site inspection. I think you should go for guniting to repair the cracks. You may take help from the website gharexpert in the construction section from the article repair of cracks.
Sun Nov 07, 2010Post  #2
RAKESH
RAKESH
Cracks in diagonal format are very dangerous as the may result in the slab collapse thus i would suggest to just replace the slab using rebarring procedure it may be costly but as you have not constructed the upper floor it is quiet opossible and will be long term sollution and also life saving.
Dining room-Interior Questions (30)
191900
9893
3966
cost estimater
3753
8420
Roof Beam crack
25607
CURING TIME FOR RCC ROOF
3980
Roof leakage
2352
laying of roof
4647
4953
3644
Dear friends i am looking for an Architect in Hyderabad, pls tell me if anybody
Last answer on 3/20/2014 8:49:12 AM. by mala. Forum started by nanajee
2539
3087
2612
Last answer on 5/26/2016 10:55:05 AM. by S L Gupta (Civil Engg). Forum started by Madhu Ranjan
1875
3348
2294
Last answer on 6/16/2021 11:37:22 AM. by S L Gupta (Civil Engg). Forum started by dnyanesh
2146
Anyone know where the pendants can be purchased?
Last answer on 2/9/2022 1:49:41 AM. by jyoti. Forum started by jp medley
2312
i want to know that how u fixed this lights behind the woodern member pls let me
Last answer on 12/31/2020 2:26:38 AM. by monu. Forum started by rimpy
2066
how much is this dining table costs?
Last answer on 8/24/2017 11:34:41 PM. by S L Gupta (Civil Engg). Forum started by mike makhzoumi
5289
if anybody have good main door frame models pics?,prefer rectagle model size 210
Last answer on 8/9/2013 10:15:39 AM. by GUNA. Forum started by rense
3010
Dining Room Vastu
Last answer on 6/10/2013 3:43:04 PM. by Nitien Parmar. Forum started by umesh
2251
HOW TO DO THIS WALL
Last answer on 10/6/2012 2:34:56 AM. by PR Jawahar. Forum started by aammiitt
2626
i need wooden railing photos
Last answer on 9/12/2012 12:26:17 PM. by Amit Hasija. Forum started by padmavathi
1678
I love the painting of the house and will like to have the picture. I intend to
Last answer on 8/10/2011 2:30:13 PM. Forum started by Okwuelu John Ike
1766
i would like to know what kind of flooring this is
Last answer on 5/25/2011 11:05:45 AM. by S L Gupta (Civil Engg). Forum started by anne
2677
Last answer on 12/2/2009 3:47:42 PM. by shakespeare fernandes. Forum started by priyanka
2411
Last answer on 7/13/2009 12:38:37 AM. by miriam oyakhilome. Forum started by Alexandra
How To Repair Cracks
