Wed Apr 25, 2012Total posts : 0
NV MANI
NV MANI
Topic: Dear friends,The underground sump (11000 litres) at my house receives drinking w
Dear friends,The underground sump (11000 litres) at my house receives drinking water supplied by city's metro water supply.Unfortunately it is noted recently that the water inside sump is seen blackish and contaminated by getting mixed with outside drain water,probably water getting entry through the tree roots.The roots from nearby tress have penetrated through side walls of water storage sump.The use of sump is therefore discontinued and the incoming valve is kept closed.The top concreted floor is paved with tiles.The manhole to enter the sump is small to assess the nature and exact extent of damage. Moreover there is no visibility even if inspection lamp is used.It is practically difficult to inspect the defect and the only option could be to cut open the top concreted portion with flooring(6" thickness) which is quite expensive and time consuming. Shall be very thankful to receive advice as how the sump can be repaired and restored at least expense?Regards,N.V.Mani.
4385
Last answer on 7/4/2020 2:05:07 AM. Forum started by NV MANI
3499
10179
3370
13538
5055
5207
6580
2615
house layout on 40*40 east facing site
Last answer on 9/9/2011 2:11:24 PM. by kawalnain kaur. Forum started by anilpande
1637
West face House, can we construct North west side face sump
Last answer on 7/4/2020 2:50:11 AM. by S L Gupta (Civil Engg). Forum started by G.Mallikarjuna
913
Sir, I have a 6500 litres 10 year old brick-plastered underground water sump. It
Last answer on 7/3/2020 10:58:35 PM. by S L Gupta (Civil Engg). Forum started by Shivakumar
1576
HiI am planning to build Water sump of 7k liters (concrete) and compound wall of
Last answer on 8/8/2017 12:00:32 PM. by S L Gupta (Civil Engg). Forum started by Tarun Kumar L K
5462
Underground water sump
Last answer on 2/27/2015 11:50:23 AM. by revadi. Forum started by hb
2064
DEAR FRIENDS, I NEED INTERIOR PICS REGARDING 4 STAR HOTEL., MAUY U PROVIDE THESE
Last answer on 10/1/2010 1:59:14 AM. by . Forum started by DHEERAJ
3644
Dear friends i am looking for an Architect in Hyderabad, pls tell me if anybody
Last answer on 3/20/2014 8:49:12 AM. by mala. Forum started by nanajee
2136
READY MIX PLASTER
3866
1686
15
17
Vastu for Water Tank
Painting
Environmentally
Environment
Environment Friendly Houses
Proper
