Dear sir,I need information for RCC Brick work estimate for 2400 sq ft plint
Wed May 07, 2014Total posts : 4
nilesh
nilesh
Topic: Dear sir,I need information for RCC Brick work estimate for 2400 sq ft plint
Dear sir,I need information for RCC Brick work estimate for 2400 sq ft plinth construction. Basically i need appx. rate / sqft for RCC and brick work estimates. The plinth area is around 1200 sqft
Wed May 07, 2014Post  #1
nilesh
nilesh
The plinth area is around 1200 sqft & 8-10 ft below ground, + Parking space / ground floor of 1200-1400 sqft + first floor residance of 1400 sqft
I would be constructing the house with Rcc contractor for my own living and need to know baseline rates with material for RCC + Brick work of above. Structual engineer also provided estimate of around 3kg/sqft of steel of the slab area as we need to do provision for future floors.
Tentative steel - 8 tonnes, Steel bars - 16mm,
brick 6" / 9" which would be good.
Thu May 08, 2014Post  #2
Dear Nilesh
       The cost of construction depend or related with the plan, elevation, structure and specification used in the construction. As you stated that you are constructing the building 8' in ground than its cost differ with building 8' above ground. Cost related with so many factors nos of windows, door railing, columns. The hit and trial method proves costly in long run.
As you stated  steel bars 3kg/ sqft is wrong it may be 3 kg/ cufeet and bars you given 16 mm is also wrong. For better option have detail estimate, which willgive you rate,cost pper item, quantity of material required according to drawing and specification.
The steel bars required are 10mm,12mm and 16mm. For more information see the link below.
http://www.gharexpert.com/articles/Start-Construction-1528/Guidelines-while-Starting-Construction_0.aspx
http://www.gharexpert.com/construction-ideas/start-construction.aspx
http://www.gharexpert.com/articles/Start-Construction-1973/Gharexpert-can-save-you-money-during-construction_0.aspx
Tue Jun 17, 2014Post  #3
nilesh
nilesh
Post subject: Ordered details estimate plan
I have ordered for a detail estimate plan. i have architect plans ready for you,
Order id: 2549
Please provide any email address where i can send the drawings
Attachments: House plan.zip Tue Jun 17, 2014,&n
Wed Jun 18, 2014Post  #4
Dear Nilesh
          Please contact or send support@gharexpert.com for sending the drawing and for any further information.
RCC + Brick work estimate for 2400 sq ft construction- Update
Last answer on 5/7/2014 4:12:37 PM. Forum started by nilesh
Last answer on 5/6/2014 5:04:11 PM. Forum started by nilesh
2515
Cement
191900
3475
labour charges rates
35210
2006
3107
Last answer on 10/5/2020 10:59:59 PM. by S L Gupta (Civil Engg). Forum started by DEVANSU
3129
3262
compound wall
2560
Specification of ‘Plastering’
2893
Foundation Brick estimate
Last answer on 7/4/2020 2:12:13 AM. by Bs Dhiman. Forum started by Bs Dhiman
2665
sir i want to know that what would be the cost total consturction of 2200 sq.ft
Last answer on 2/15/2022 11:12:49 PM. by JAI PRAKASH. Forum started by shruti Adarsh
1972
Elctrical wiring
1916
traditional house construction
Last answer on 2/24/2014 6:28:15 PM. by Shanthakumar. Forum started by vikram
2996
RATE OF KOTA STONE
Last answer on 12/11/2014 11:55:18 AM. by seema tyagi. Forum started by sanjay
3347
2564
Labour Cost
Last answer on 8/5/2014 8:13:30 PM. by JAI PRAKASH. Forum started by ferous
2869
FOR 250 SQ FT R-B-C SALB RATE
What is acre
Brick Arches
