Home -> Forums -> Interior -> Home Improvement -> Decorative paint vs Wall paper
Wed Sep 15, 2010Total posts : 3
chanchal
chanchal
Topic: Decorative paint vs Wall paper
Wehave just purchase a flat and we are thinking of decorating one wall in each room and this is a 2 bhk flat..what would be the best option for decorating walls...decorative paint or wall paper in terms of durability and cost as well. I have seen some very good wall paper designs but some of our friends are suggesting paint ...reason  is durability.. please suggest and what would be the approximate cost for both the options. Flat size is 1299 sq ft.
chanchal
Thu Sep 16, 2010Post  #1
Dear Chanchal
    Wall paper is that it is harder to do but once it is done it lasts a long time. You can get 10 to 15 years from wallpaper and adds value to your home.
But in my view there are some disadvantages of wallpaper;-
1.  Humidity can cause it to become unglued.
2. It is easily spoiled and damaged in case small children of yours or of yours guest.
3. Older paper nearly impossible to match color or pattern if damaged.
4.  Costly to replacement.
2.      Paint is the most popular and practical wall treatment as it is quick, easy, and generally the least expensive way to give a room an instant "makeover".
Thu Sep 16, 2010Post  #2
Geetanjali
Geetanjali
See there are lot of options for decorating the wall (not only with paint).
But e.g. in master bed you can go for some textured paint with some spot lights on wall decorated with beautiful paintings.Color shade of which  you can change after few years easily because with one theme for long time you will get bored of it as every one like change after few years.For kids bed ( I dont know the age if you have)you can go for some cartoon or shadow paintings on walls.Hope this is useful for you.
Ar.Geetanjali
Attachments: City-skyline-room.jpg Thu Sep 16, 2010,
Monkey-Tree-Room.jpg Thu Sep 16, 2010,
Silhouette-willow-room.jpg Thu Sep 16, 2010,&n
Tue May 08, 2012Post  #3
Ar. Manoj Ralen
Ar. Manoj Ralen
Hi Chanchal,
These are some of the  options available to you.
1) Go with Wall paper:  You may want to go with Wall papers as they have the following benefits.
1.1) Wall papers have almost unlimited designs and the quality of work in the actual completed wall is more or less same as the wall paper sample that you would see.
1.2) Pasting the wallpaper do not require experienced labor.  If you go with designs using paint then the experience of labor can considerably affect the output of the job and finding labor may not be the easiest thing
1.3) Texture paints have limited designs. Ofcourse a very experienced painter can product unlimited finishes but then that person is hard to find and he/she would not be able to show you before hand what the final output would look like.
2) Go with Textured Paint:
2.1) Some cities have limited wall paper vendors so you can go with textured paint if you don't like the wall paper design.
2.2) Paint is more durable than wall paper but if the seepage or moisture is there on the walls then it would affect both wall paper and textured paint.
2.3) Paint work can be easily repaired whereas wall paper match would be harder to find as the wall papers go out of stock with vendors very quickly.
3) Go with regular paint with stickers
This combines the benefits of paint and wall papers as you can get all walls painted through your painter and then put stickers to create themes in those rooms.
Enjoy
Home Improvement-Interior Questions (38)
2400
hi I would likt to know about the wall drawing is it a paper wall or wall painti
Last answer on 8/27/2021 3:17:36 PM. by . Forum started by mollergh
3035
on bed back wall is it a texture paint or a wall paper pl clarify.
Last answer on 12/31/2020 2:29:50 AM. by Karan. Forum started by Sanjeev Khanna
2257
i think so its a paper wall.
Last answer on 10/24/2021 12:20:07 PM. by Nikita. Forum started by rupali
4568
PAINTING
Last answer on 2/24/2022 12:54:30 PM. by Girish. Forum started by Girish
2211
Hello this sajid Apna ghar i would to ask about the sizes of wall paper rolls.
Last answer on 5/23/2012 2:01:56 PM. by sukamalroy. Forum started by sajid
4510
Wall Putty ,primer and paint
2778
Is this paint or tiles on wall?
Last answer on 3/30/2011 9:13:41 PM. by Mohini Sharma. Forum started by rupali
2288
I would like to know the colour to paint on the walls as per vastu
Last answer on 6/11/2013 3:11:08 PM. by geetika. Forum started by nagaraja k.n.
2732
plz send me pic two wall texture and other paints and i want texture on celing
Last answer on 2/14/2022 11:13:57 AM. Forum started by nauman
3727
Very good I want to no how to paint it on walls, plz reply soon
Last answer on 7/3/2020 10:44:31 PM. by S L Gupta (Civil Engg). Forum started by zahid
2478
which paint using for wall
Last answer on 7/28/2010 1:46:28 AM. by ashu jain. Forum started by firoskhan
2365
estimation
2575
2216
how to clean sunmica doors
Last answer on 7/15/2021 12:45:52 AM. by HardissonHard. Forum started by Anu
4635
time for paint and wall putty
2133
At first you have to see where is the pillar in your bed room. what is the other
Last answer on 3/29/2010 11:53:19 AM. Forum started by arrup sarkar
3083
667
Advise me who can prepare a good term paper?
Last answer on 6/29/2021 4:11:09 AM. Forum started by Alan White
1921
>Is that wall paper? (brown/cream) >If that is wall paper, how much per roll an
Last answer on 8/31/2012 11:08:09 AM. by Ar. Manoj Ralen. Forum started by char
2361
Refinish a Vinyl Floor
2526
Introduction
1094
Home appliances
2373
2968
layout plan
2182
Window Curtains For Home
3430
Reg: Interior design software
2724
Living Room Decoration Ideas
2242
2040
2219
floor tiles
804
Online dating
2548
4046
Paint vs Wallpaper
2532
Design for a pooja room
9544
Wall Putty and primer
2018
Straight Drop Awnings
2758
Kids Room Theme
2023
sapty tank
Canvas
Canvas Wall Art
Bedroom Accessories: Style Statement for Bedroom Decoration
Accessorize your bedroom for comfortable or luxurious bedroom decor. Bedroom accessories give fine details to bedroom ..
Wall
Wall Accents for Your Rooms
Wall
Wall Decor
