Home -> Forums -> Construction -> Layout and House Plans -> Demarcation between RCC beam and brick wall
Thu Sep 23, 2010Total posts : 1
Radhakrishnan
Radhakrishnan
Topic: Demarcation between RCC beam and brick wall
I plan to instal a split A/C in my living room.This flat had been remodelled by the original owner and a French window of size 102" x 70"height.has been installed.The top part of the French window has been fitted at a height of 26" from the ceiling andthe bottom part at 9" from the floor..The total ceiling height is 112" The 7" difference in between [ 112"-(70+26+9)] is due to the marble facings provided for the window.
My problem arises in installing the cooling unit above the french window. I want to know aat what height the RCC beam is installed, so that I can safely drill holes for the cooling unit inlet, outlet pipes as well as condensate drain and electrical wiries.
If I know the demarcation distance between the RCC beam and the brick portion, I will be relieved.
I live in a seven storied building (grd+6)
Fri Sep 24, 2010Post  #1
Dear Radhakrisanan
                 It is better if you call any  local civil engineer or contractor who is in better position to solve your problem after inspecting the site of your house i.e. it is to be seen that wall you are drilling is weather load bearing or non load bearing, size of wall to be dismentel, size of beam or lintel to be casted according to the site condition.
4799
tie beam obsolete
3574
2054
9196
2279
Cost of additional room construction
Last answer on 2/14/2013 11:20:09 AM. by S L Gupta (Civil Engg). Forum started by anil
5861
1702
1366
1865
1771
please advise size of RCC beam of 17'7" span, of which one end will be based on
Last answer on 7/23/2015 1:13:28 PM. by S L Gupta (Civil Engg). Forum started by r.n.misra
1950
2159
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by S L Gupta (Civil Engg). Forum started by arctushar
2525
2719
3837
Roof Beam
35211
1797
RCC foundation instead of brick foundation
Last answer on 9/23/2015 8:37:51 AM. by gpeter. Forum started by gpeter
21329
how much cement is required for 100 sq wall for plastering and brick work.
Last answer on 3/14/2013 2:12:10 PM. by S L Gupta (Civil Engg). Forum started by paresh
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Centering
