Demolition of RCC roof.
Tue Apr 30, 2013Total posts : 1
Ashok Vashisht
Ashok Vashisht
Topic: Demolition of RCC roof.
I had constructed about 800 sq feet of my ground floor out of the total 2000 sq feet. Now I am constructing the rest 1200 sq feet. In an earlier post I had sought advice on jointing the old and new RCC roofs. However, due to some design changes and the fact that a single cast RCC roof will be better than a jointed one I am demolishing the (old) 800 sq feet RCC roof. During the process of demolition I want to ensure that there is no damage to my walls / the cement bonds in the brick walls /vertical RCC pillars / PVC Pipes running in my wall. How do I ensure this ? I understand that a lot of energy will be released into the structure by the demolition hammers!
Tue Apr 30, 2013Post  #1
Dear Ashok
      If with the reason that single cast RCC roof is better, than I am in view that do not demolish the already laid slab. In big structure one should provide construction joint and expansion joint. Rather dismantlement you should take help of any civil engineer or structural engineer, who will guide you about the joint of slab. There are various method to lay the slab in such circumstances.
9893
2992
6381
kota Stone Roofing
3754
2054
4648
3980
Roof leakage
1875
4953
2255
Hello members..i am building a small bungalow in Karjat .Mumbai.. and would like
Last answer on 1/27/2015 7:22:56 PM. by JAI PRAKASH. Forum started by FRANCO VAZ
13756
2539
3838
Roof Beam
6412
RCC Roofing Cost
Last answer on 12/11/2013 11:01:19 AM. by S L Gupta (Civil Engg). Forum started by Praveen Srivastava
2616
Exterior Walls
2613
Last answer on 5/26/2016 10:55:05 AM. by S L Gupta (Civil Engg). Forum started by Madhu Ranjan
18
Cooper
