Home -> Forums -> Construction -> Foundation -> Designing a Foundation
Thu Jul 30, 2009Total posts : 37
cosntruction novice
cosntruction novice
Topic: Designing a Foundation
For foundation and columns, I have been advised to use "dust" rather than "ghagger sand" -- which my contractor is using. ANy thoughts? How do I differentiate dust from what is being used right now..
The comment above talks about the article   "Designing a Foundation "
Go to page: 1 2 Next   >>
Tue Aug 11, 2009Post  #1
H S Rathi
H S Rathi
Post subject: Sand for foundation work
Ghaggar sand is river sand received from river Ghaggar where as dust is the product received from crusher by crushing stone boulders. The sand required for columns should be coarse sand and silt contents should not exceeds 4 % . You can wash the dust to minimize the silt contents. For more detail about coarse sand/ fine aggregate you can take help from link given below.
Sand for construction
Thu Jan 28, 2010Post  #2
seetharam reddy
seetharam reddy
Post subject: Designing a Foundation
very good site, gives basic idea , how to proceed in constructing new house. thanks msreddy
Sat Feb 06, 2010Post  #3
venkataratnam
venkataratnam
in the construction area there was a coconut tree earlier and the same was remoed by cutting upto ground level 3 years back. Now is it necessary to remove by digging same.As the same was dead in the ground. presently It will not give any problem for construction work.
Fri Jun 18, 2010Post  #4
Nandan Kumar
Nandan Kumar
I want to construct ground plus three level building in area of about 800 sq ft in faridabad. My Engineer has suggested me 9"x9" column size with 4 no.s of 12mm steel, 8mm ring, 150c/c. Total no. of columns are 12. I just want your views regardign column size.
Fri Jun 25, 2010Post  #5
vijay
vijay
how can i have foundation which is earthquake proof.
Tue Jun 29, 2010Post  #6
umesh
umesh
i want to construct a g+3 1000 sft house in guwahati what would be the cost for the ground floor
Wed Aug 04, 2010Post  #7
SHEKHAR
SHEKHAR
Is it possible to get some 3D front elevation for my upcoming G+1 ( MAY BE I SHALL ADD 2nd FLOOR LATER)in DURGAPUR(W.B.),if needed i can provide the copy of the plan. Also, pl. tell is vitrified tiles better than the makrana/dungri marble which is around Rs.60/psq.ft. And how can i do exceptional interiors of my house without spending too much money. Thnx !
Mon Aug 09, 2010Post  #8
R. Damodhar
R. Damodhar
Can any body tell me how to prepare the estimate/rate analysis for centring (shuttering) work; can directly mail to me.
Mon Aug 09, 2010Post  #9
vimal
vimal
Dear Vijay,
Look at the articles listed on the link given below:
Thu Sep 23, 2010Post  #10
natarajan
natarajan
thanks a very useful site
Thu Sep 23, 2010Post  #11
natarajan
natarajan
can you tell laying antitermite treatment at foundation lelel
Thu Sep 23, 2010Post  #12
natarajan
natarajan
Post subject: desinging a foundation
can you tell about laying antitermite treatment at foundations
Sat Oct 09, 2010Post  #13
mathi
mathi
anyone give some suggestion for footing in soil having very low SBC
Sat Oct 23, 2010Post  #14
saravanan
saravanan
why red soil to be filled? what is acceptence criteria for red soil.
Tue Oct 26, 2010Post  #15
Manjeet Singh
Manjeet Singh
Excilent & very helpfull information, Very soon I am going to start built a house at Noida. I will try to built myself will you help me time to time while construction.
Thu Nov 11, 2010Post  #16
kapil advani
kapil advani
we have plot 272 guz 35 fut frunt 70 fut depth we want make plot duplex styal pl. give estimate for complite work we want 4 room kitchan dring room living area thanks
Tue Nov 16, 2010Post  #17
SUNIL
SUNIL
what is the correct procedure to measure the plinth height(either from ground level or from bottom of ground beam)
Sat Nov 27, 2010Post  #18
Mathew John
Mathew John
I want to construct a house on a water logged plot.As per my structural engineer, single bulbe under reamed piles of 8.5m depth x 22 Nos ie., 400mm dia x13 nos and 500mm dia 9 nos =22 nos. Bulb size is 1000 and 1250 respectevely.How to make an estimate?
Sat Jan 29, 2011Post  #19
aa7s7y
aa7s7y
max plumbob variation allowed at the time of column wooden shuttring and give me check list for columns, beams and slab
Sat Jan 29, 2011Post  #20
Nikita
Nikita
Post subject: Shuttering and Checklist for Column, beam and sl...
Dear Friends,
You can easily take help from some the links given below:
Centering and Shuttering
Column and Frame Structure
RCC Roofing.
1850
Foundation -- Urgent
Last answer on 7/29/2014 1:14:27 PM. by S L Gupta (Civil Engg). Forum started by Debojyoti
1657
Foundation Const-Lko -2750 Sqft Cornor Plot
Last answer on 8/9/2015 5:58:08 AM. by Purvi Panchal. Forum started by Manjeet
1872
1050
2545
Foundation design
3126
Last answer on 7/31/2020 7:39:42 AM. Forum started by Prahbjot Singh
2483
Pile Foundation
2403
Last answer on 11/18/2013 10:57:21 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
1906
Last answer on 11/18/2013 10:38:53 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
3857
4930
4235
2307
724
Hi sir,I have already make a foundation so I need
Last answer on 7/3/2020 10:30:07 PM. Forum started by Malik
2055
Last answer on 4/6/2016 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by zakia sultana
1691
material requirememt question
Last answer on 12/26/2015 7:41:53 PM. by JAI PRAKASH. Forum started by sushantsah
6500
1781
RCC foundation instead of brick foundation
Last answer on 9/23/2015 8:37:51 AM. by gpeter. Forum started by gpeter
2656
Pillar
2126
Curing urgent
2346
structure work
5150
Pillar foundation
new house
2806
building a house
1980
Construction Agreement
3082
Foundation
2259
Foundation
1464
10029
3647
Foundation
2102
Structure proof checking
2545
Foundation design
2430
2455
Saria and cement
3634
Wall Thickness
2659
3144
13244
Steel Type
Designing
Porch
Porch Designs
Ceiling
Design
Design your Office
