Home -> Forums -> Construction -> Start Construction -> Difference b/w company and factory manifectured cement
Thu Feb 21, 2013Total posts : 1
Topic: Difference b/w company and factory manifectured cement
what is Difference b/w company and factory manufacturing cement?
Fri Feb 22, 2013Post  #1
Dear Paresh
        I think you want to know about the cement manufactured by the factory or standard company and cement made by the plant.
The factory cement is according to ISI testesed in lab Where as plant cement is made at local level and not hold good for construction.
1659
Last answer on 7/15/2017 12:48:17 AM. by S L Gupta (Civil Engg). Forum started by Frank lun ngaihte
3591
2002
Please eleborate on vastu for Factory building and plot
Last answer on 6/19/2010 7:45:16 PM. by sabina vanjani. Forum started by Vijay Narang
2165
Last answer on 7/4/2020 2:33:32 AM. by S L Gupta (Civil Engg). Forum started by Monish Salhotra
1872
SOUND PROOF MATERIAL FOR CEILING IN FACTORY
Last answer on 2/7/2013 6:03:59 PM. Forum started by saif
21330
how much cement is required for 100 sq wall for plastering and brick work.
Last answer on 3/14/2013 2:12:10 PM. by S L Gupta (Civil Engg). Forum started by paresh
4950
1450
are their any other companies apart from dupont who are importing corian or simm
Last answer on 7/29/2009 10:58:06 AM. Forum started by sheeba
2166
am happy to be part of this company.
Last answer on 6/19/2011 10:32:37 PM. Forum started by kunlex
2024
Industrial Maintenance
Last answer on 5/14/2021 10:32:21 AM. by S L Gupta (Civil Engg). Forum started by MarianneRolfe
909
What should be a company that deals with moving offices?
Last answer on 4/3/2021 12:44:35 AM. by Nafen. Forum started by aglar
1130
How to choose an IT outsourcing company for a startup?
Last answer on 12/3/2021 9:50:42 PM. by benjaminburke. Forum started by terimad
639
Which companies can provide high-quality translation of medical documents?
Last answer on 6/30/2021 2:39:08 AM. Forum started by terimad
480
Is it possible to create your own company without knowledge in this area?
Last answer on 1/25/2022 11:59:36 AM. by Rinder76. Forum started by Salammm
392
1978
Transport
Last answer on 4/2/2016 12:12:42 PM. by S L Gupta (Civil Engg). Forum started by Bunkera1993
2327
Materials
2827
3470
paint
3312
2236
2312
2061
Checklist for Cement Plaster
Buying
Buying tips for Cement
Tips for Cement Paint
Gray
Gray Cement
Do you know the strength of a building depends on the quality of cement? Cement/ Gray cement is one of the most import..
White
White Cement
You can boost up architectural beauty of your home using white cement since the strength of building and its component..
Cement
Cement Concrete
