Home -> Forums -> Construction -> Raw Material -> Difference between Mortar and Masonary Plastering
Tue Oct 11, 2011Total posts : 1
sunny420
sunny420
Topic: Difference between Mortar and Masonary Plastering
What is the Difference between Mortar and Masonary Plastering and which is best, quality and costwise..
Fri Oct 14, 2011Post  #1
Dear sunny
        The mixture of cement and sand in any ratio is called cement mortar. cement mortar varries according to the ratio i.e. 1 part of cement with 4 parts of sand is known as 1;4 similarally ratio is 1;2, 1;3 so on. There is no differance in cement mortar of masonary or plaster. It has differance in ratio.
2553
Mortar Plastering
Last answer on 10/11/2011 6:37:02 AM. by S L Gupta (Civil Engg). Forum started by sunny420
3591
1666
Last answer on 7/3/2020 11:11:05 PM. by Navneet Jharia. Forum started by Sandeep
1894
2749
2924
2841
Water seepage from RCC slab
3590
Per Sq:ft rate for flooring
3873
centering shuttering formwork
Last answer on 5/10/2011 5:09:34 PM. by S L Gupta (Civil Engg). Forum started by navin kotian
3207
Nubian Vaults
Last answer on 12/31/2020 1:57:43 AM. by H S Rathi. Forum started by Boovarahan S
1958
2068
difference betwen block board and ply board
Last answer on 12/31/2020 2:51:40 AM. by Chetna. Forum started by manisha
2486
Last answer on 9/20/2010 8:49:58 PM. Forum started by A Prasad
2119
Difference b/w company and factory manifectured cement
Last answer on 2/22/2013 11:30:32 AM. by S L Gupta (Civil Engg). Forum started by paresh
2319
cement
Last answer on 8/25/2012 12:33:40 AM. by Ar. Manoj Ralen. Forum started by abhijeet joshi
1759
2419
surveying
Last answer on 5/27/2021 1:53:39 PM. by Bill Shiphr. Forum started by shaik khaja nayab rasool
1619
3470
paint
3075
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11104
2189
2037
Estimate
11123
3073
Steel
3039
use of tmt bar
1642
work turned out by labour
2457
estimate
1762
2992
3606
1943
Cost of Steel construction
1613
2136
READY MIX PLASTER
1864
2223
zero slump concrete
Checklist for Cement Plaster
Gypsum
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
Brick Bonds
Do you know good brick bonds can ensure the strength of a building? Only you need to select appropriate bond for walls..
