Layout and House Plans
Wed Apr 12, 2017
Vandana Joshil
Topic: Difference between Silt and Ground
In a house with Ground plus two floors, is the Ground floor structure with which is used for residential purposes considered as Ground or is it stilt?
Wed Apr 12, 2017
In my view when there is residential house at ground than it is called as ground floor but when we use ground as parking than this will be stilt.
2102
river sand
Last answer on 4/21/2014 3:55:50 PM. by
shaik khaja nayab rasool
2368
Types of Soil
Last answer on 7/3/2020 11:36:07 PM. by
gpeter
2419
surveying
Last answer on 5/27/2021 1:53:39 PM. by
Bill Shiphr
3470
paint
Last answer on 2/14/2022 1:30:01 PM. by
Last answer on 10/5/2014 2:44:13 AM. Forum started by
tushar bhoj
2068
difference betwen block board and ply board
Last answer on 12/31/2020 2:51:40 AM. by
Chetna
manisha
2486
Last answer on 9/20/2010 8:49:58 PM. Forum started by
A Prasad
3873
centering shuttering formwork
Last answer on 5/10/2011 5:09:34 PM. by
navin kotian
2319
cement
Last answer on 8/25/2012 12:33:40 AM. by
Ar. Manoj Ralen
abhijeet joshi
2119
Difference b/w company and factory manifectured cement
Last answer on 2/22/2013 11:30:32 AM. by
Last answer on 5/25/2021 9:21:56 AM. by
HardissonHard
Sree
2531
advice for silt/basement parking
Last answer on 4/3/2013 4:49:18 PM. by
R Kumar
R Kumar
2412
labour
Last answer on 5/14/2013 3:14:12 PM. by
Kilyen Rampton
dan
2055
AIR COOLING V/S AIR CONDITIONING
Last answer on 3/13/2013 9:48:14 AM. by
Ravi
difference b/w colum, beam and RCC slab
Last answer on 7/25/2013 5:09:29 PM. by
LAKWINDER
mosaic or tiles
Last answer on 3/19/2013 5:06:52 PM. by
Jemimmarichardson
aammiitt
5207
Last answer on 9/17/2012 4:28:54 PM. Forum started by
Amatuer
5943
Difference between Mortar and Masonary Plastering
Last answer on 10/11/2011 6:39:09 AM. by
sunny420
1560
Does vastu make any difference when we made our home??
Last answer on 4/5/2011 3:36:36 PM. by
Nikita
yatu
2691
Raj
2188
Amutha
2184
vanramr
2791
raghu
4520
Nitien Parmar
suryarao p
1890
santosh
2284
Deepak Giri
2265
ajay sharma
2766
u v sudhakar
3464
ramana
2356
srinivas kamsali
1967
tanaya483
2242
ramanapeddu
3595
SRIKANTH.S
2324
HIRA SINGH
2792
Alexander Graf
Mohiuddin
1548
uma shankar
2114
mohammedbasha
Pool Pumps
Which are various types of termites?
In nature, subterranean termites are beneficial. They break down many dead trees and other wooden materials..
Vastu for Water Tank
Inground Swimming Pool
