Sat Jan 19, 2013 | Total posts : 5 |
| Topic: Difference between plot size area, built-up area, plinth area
Unable to understand the difference between plot size, built-up area, plinth area words in context of construction. For instance, If we have 32 by 70 (249 sq yds) plot and planning for ground plus 2 floors. ground half portion is leave for parking and remaining half for 1BHK portion and remaining 2 floors, each floor 2 x 1BHK portions. Assume 3ft from road open to sky. Then how to come with plot size, built-up area,plinth area.
Regards Vamsi M
Mon Jan 21, 2013 | Post #1 | GUNA
Join date: Feb 2012 | Post subject: Difference between plot size area, built-up area...
Hi Vasim
PLINTH AREA - It is the area upon which a structure rests. CARPET AREA - is the area which we use i.e. usable area SUPER BUILT UP AREA - it includes BUA (Built up area) plus passages, stairs etc. Here BUA is usable area plus thickness of inner & outer walls. | |
Thu Jan 24, 2013 | Post #2 | vamsi
Join date: Oct 2010 | Thanks guna for the clarifications. So, will explain what I understood with an example. plot size is 40x60 = 2400 sq.ft Planned construction is Ground+2 floors, Each floor had two 1BHKs, each 25x24 (600 sq.ft) including outer walls (mean plinth area), carpet area 24x23 sq.ft each Floor slab is 30X48 = 1440 ( included stair area) So, Super BUA will = 1440x3 = 4320 sq.ft ( G+2 ) Could please validate and correct if my misunderstanding Vamsi M | |
Thu Jan 24, 2013 | Post #3 | GUNA
carpet area will not be exactly 24x23, you have to reduce internal wall area also other items are ok for understanding | |
Thu Mar 17, 2016 | Post #4 | Arvind
Join date: Mar 2016 | Post subject: Payment info require
I want info about new budget real estate,Suppose Carpet are is 425 and 200 is another area so as per new budget rule at what proporionate or how much amount i have to pay to builder?or in same rate we have to pay for both or any? is there any difference in carpet area and built ip area | |
Thu Mar 17, 2016 | Post #5 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Arvind Carpet area is the area of floors of house which is usable. Built up area is total area of construction including carpet area and internal and outer walls. For payment take help from property consultant as they have go trough the new real state bill.
Layout and House Plans-Construction Questions (39) | |
Articles that might interest you! | | Selection of A Site The selection of a site depends upon ones present and future spatial requirements, the envisaged available funds, one’.. | | Rugs for Living Room Give modern and contemporary look to your living room with wide range of area rugs and carpets. Living room rugs are p.. | | What is recommended size and shape of building for the protection in earthquake prone areas? All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s.. | | Utilization of Space Under Stairs It seems that most people forget to decorate the space under stairs. Though the space is small yet it’s easy to create.. | | What are various termite control methods? INITIAL INSPECTION AND REPORT requires a complete thorough inspection of the buildings and surrounds, and a detailed w.. | | Vaastu for Plot Building a dream home needs vigilant considerations and apart from the good architectural design and construction tech.. | | EAST FACING PLOT A north-east facing plot is best for all type of constructions, whether a house or a business establishment. However, .. | | Shape of the PLOT The shape of a plot really affects the prosperity it would be generating. So before choosing your plot check out the .. | | Balcony Balcony is an extended platform that projects from a wall(interior or exterior) of a building, supported by columns an.. | | Outdoor Rugs Outdoor rugs grab attention and are aesthetically appealing. These rugs are usually used for door mats, swimming pool,.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
