Home -> Forums -> Construction -> Start Construction -> Different types of ceilings.
Fri Mar 25, 2011Total posts : 3
Amogh Desai
Amogh Desai
Topic: Different types of ceilings.
Have a 25 year old house in Goa, custructed using laterite stone.  It doesnt have an architectural design and was expanded as and when needed over the period of 25 years.  Just after the main entrance ther is a hall of 20 x  13 ft, this Hall is exactly in the middle of the house and its walls are elevated to a hight for future improvements to add another floor.  the walls are around 22 ft high with a typical Manglore (red) tiles.  Now I wish to put a ceiling to add another flore at around 10 feet hight.
My question is what is the most cost effective solution to this ??  I do not wish to put RCC slab on this.  Is there any other alternative ???
Amogh
Fri Mar 25, 2011Post  #1
Dear Amogh
              There are other way for roof such as
   1. you may go with RSS Joist, batten and stone slate roof.
  2. Other option is Iron truss and AC Sheet roofing.
 3.Iron truss and  GI Sheet roofing.
Mon Mar 28, 2011Post  #2
Amogh Desai
Amogh Desai
Thanks Mr Gupta for your response.  I also read about Ferror -Cement as an alternative to RCC and is much cheaper.  I couldnt find much information to what it is exactly and if some one can provide this way of construction in Goa.
Could you give me some information about this too ???
Amogh
Tue Mar 29, 2011Post  #3
Dear Amogh
             Ferror -Cement  is mixture of cement coarse sand reinforced with layers of woven steel mesh and closely spaced small dia steel bars. You can go ahead with this option also.
2284
i want to see different type of POP on ceiling
Last answer on 12/31/2020 2:33:42 AM. by jaydeep. Forum started by radheshyam
2725
Wooden Flooring
Last answer on 2/9/2021 5:39:37 AM. by Prakash Pandey. Forum started by atiq khan
3252
2037
PVC windows
2687
could you send me some more good designs not satisfied with this type of pop cei
Last answer on 6/23/2021 6:18:33 AM. by Richa Shangvi Interior decorator. Forum started by maya
2708
5439
Best branded and economical Lights for false ceiling in various rooms...
Last answer on 8/23/2012 6:04:51 PM. by Ravi. Forum started by raghuam
2836
13637
overlap length to steel
2237
Flooring for house
Last answer on 1/17/2022 11:13:36 AM. by S L Gupta (Civil Engg). Forum started by Archit Jain
2044
Should persons with different name and or profession have main door entries in d
Last answer on 2/5/2022 2:03:11 AM. Forum started by Vinod Kothari
3278
i want different designs of pooja ghar
Last answer on 7/3/2020 9:49:04 PM. Forum started by vrinda thatte
2286
show me different pop design
Last answer on 10/4/2012 3:26:01 PM. Forum started by Afolabi Tope
1758
Mold & fungi at wall bottom sides
Last answer on 5/18/2013 1:55:52 PM. by S L Gupta (Civil Engg). Forum started by bharat
2469
door design
Last answer on 2/14/2014 4:17:10 PM. by Navneet Jharia. Forum started by chethan
2413
door design
Last answer on 11/24/2021 10:01:15 PM. by S L Gupta (Civil Engg). Forum started by chethan
1963
what are the different good wooden flooring options available...pl suggest
Last answer on 5/23/2011 10:12:30 PM. by S L Gupta (Civil Engg). Forum started by Reena
2553
very nice picture and very different also.
Last answer on 10/9/2020 12:49:36 AM. Forum started by AMITKATHURIA
2293
i would like to see some different color combinations as well
Last answer on 4/28/2010 1:15:34 PM. by juhi. Forum started by fawad
2442
3265
3278
4424
3970
2187
2695
4205
5159
2370
2288
1991
2441
2110
3190
2041
12508
2157
2005
2721
Dining
Dining Room Ceiling
How to clean plaster ceiling?
Kids
Kids room ceiling designs
Ceiling
Living Room Ceiling
Ceiling
Ceiling Lighting
Ceiling
Ceiling Fans
Basement Ceiling
Which type of finishing is recommended for wooden ceiling?
The exposed sides of the boards are made plane and smooth.
