Foundation
Dirt Floor Foundation Girder Repair
Sun Oct 30, 2011
Ben
Topic: Dirt Floor Foundation Girder Repair
We have a 2 foot crawl space under our house with a dirt floor. There are 3 girders running horizontally, with the middle one completely rotted out. I'm looking to replace that girder.
I've laminated the joists in the center of the house and lifted a square area with 4 concrete block piers; 2 on each side of the middle girder. I plan on installing 2 ply 2x10 treated wood in place of the old 1 ply 2x8 (pretty bad I know).
There are a lot of details that I need to ask about to be sure I proceed correctly from here.
1. Do I need a preservative on the ends of my girders, which will rest on a concrete wall around the perimeter? I'm using pressure treated wood from Lowes.
2. Will wood screws be good enough for holding the girder together, or is it required that I use a glue? If so, what should I use?
3. I have heating ducts near the middle girder. If I were to install some form of insulation to prevent the heat from creating humidity, what should I use? Water gets down there when it rains heavily, and any precautions I can take would be great.
4. Do I need to seal the concrete blocks I use as piers with a sealer? Or can I simply apply pressure from the house on them and they will hold? If I need a sealer, can I apply it onto blocks that are already stacked, or will I need to stack them over again?
If you can answer any of these questions, I'd appreciate it. Thanks.
1805
How to repair the suspension crack floor
Last answer on 2/4/2015 11:31:02 AM. by
BAURO
2326
Last answer on 4/13/2011 6:59:26 AM. by
rammohandas
2025
Industrial Maintenance
Last answer on 5/14/2021 10:32:21 AM. by
MarianneRolfe
2065
Last answer on 10/15/2014 8:31:38 AM. by
naresh
1666
Can two foundation beds with basements be joined and maintain the structual stre
Last answer on 10/25/2014 8:54:11 PM. by
Gireesh
1768
I have a house constructed in 1991 with 5 feet foundation. It is not a pillar fo
Last answer on 11/12/2014 2:13:35 PM. by
S Nagarajan
1943
Last answer on 11/25/2016 2:18:45 PM. by
Khalid Rashid
1998
I have a house constructed in 1991 with 15 feet foundation. (It is a pillar foun
Last answer on 1/16/2015 2:09:58 AM. by
Manoj
Last answer on 6/9/2015 4:30:39 PM. Forum started by
Debi Prasad Nayak
2823
building a house
nashir
2700
Last answer on 8/16/2016 11:39:31 AM. by
freekundli
MASTHAN
1895
santosh
1069
Last answer on 1/25/2021 8:28:32 AM. by
Sonu Adak
2342
Last answer on 2/4/2015 11:35:37 AM. by
Arun
1888
Damp
Last answer on 4/4/2015 7:00:17 PM. by
Jag
2900
Last answer on 12/31/2020 2:07:59 AM. by
Karan
tkalaiva
6587
Last answer on 10/16/2014 12:42:44 AM. by
NV MANI
9211
Vinod
2038
Dear Gupta sir,Can you please suggest the detailed specification for a good foun
Last answer on 5/8/2013 12:14:58 PM. Forum started by
nithun
2690
Pillar
Last answer on 2/24/2022 11:04:22 AM. by
keshavthakur
2143
Curing urgent
Last answer on 2/23/2022 5:17:08 PM. by
Rohit Sharma
Pooja
2379
structure work
mamtagarg
manish agarwal
5169
Pillar foundation
Last answer on 2/1/2022 10:02:34 AM. by
joe kurian
joe kurian
2212
new house
Last answer on 1/5/2022 2:13:15 AM. by
Janette
ananth
2823
building a house
nashir
1994
Construction Agreement
Last answer on 12/21/2021 12:56:56 AM. by
Abhijit
3092
Foundation
kamal
2275
Foundation
Last answer on 12/20/2021 6:20:53 AM. by
Gagandeep
1479
Last answer on 11/13/2021 8:11:49 AM. Forum started by
passwordc
10056
manishkumar
manishkumar
3667
Foundation
Rohit Sharma
2119
Structure proof checking
Arnab Ghosh
2561
Foundation design
DavidFlores18
nithun
2466
Last answer on 5/22/2021 11:37:00 PM. by
mayowa
2470
Saria and cement
Last answer on 3/25/2021 4:28:11 AM. by
ARVIND GOYAL
3659
Wall Thickness
Last answer on 12/31/2020 2:31:58 AM. by
shankar
2682
Last answer on 7/28/2020 12:37:29 AM. by
K M Sendhil
3188
satya
13272
Steel Type
Last answer on 7/4/2020 2:48:38 AM. by
erbharathi
sumit dua
Designing a Foundation
How To Repair Cracks
Termite Damage Signs and repairing tips
Termite damage is a worst dream for any house owner. Termites eat wood and this affect almost every wooden product lik..
