Dishwasher under slab. As seen on amazon almost all dishwashers are 845mm high a
Mon Sep 09, 2019Total posts : 1
Surinder Singh
Surinder Singh
Topic: Dishwasher under slab. As seen on amazon almost all dishwashers are 845mm high a
Dishwasher under slab. As seen on amazon almost all dishwashers are 845mm high and 24"x24" WxD . 845 is 33 1/4 " . In rcc slab the slab granite comes to 3 1/2 " at minimum. That means if you want dishwasher under slab, the slab top must be 33 1/4" 1/4 (margin) 3 1/2 " slab with granite = 37" . Even with 2" slab of modular style, the top would come 33 1/2" 2 = 35 1/2" . Can the legs of dishwasher be removed and if so what is reduction in size? or if someone can suggest a dishwasher with height less than 32"
Thu Sep 19, 2019Post  #1
Surinder Singh
Surinder Singh
Post subject: Thank you for reply.
Thanks for the inputs.
how efficient is a dishwasher for indian style of cooking?does it clean cooker
Last answer on 10/16/2014 12:30:18 AM. by JAI PRAKASH. Forum started by neelam rathi
1095
Home appliances
637
Useful home appliances
Last answer on 11/12/2021 9:49:09 AM. by Asecrizur. Forum started by Quovino
2107
I have a 1650sq ft flat which I am renovating What company/material I use for a
Last answer on 4/14/2013 3:03:56 PM. Forum started by capt vngautam
high crystal ceiling board of high quality for sale
Last answer on 9/21/2012 7:16:18 AM. Forum started by grace
2896
Labour rate
Last answer on 7/4/2020 2:47:30 AM. by S L Gupta (Civil Engg). Forum started by M Prabhu
1607
Understanding the Role of Architects & Interior Designer
Last answer on 3/5/2016 10:14:26 PM. by JAI PRAKASH. Forum started by rahulsharma
191930
4073
2041
option other than rcc deck / balcony @ residence
Last answer on 9/4/2014 7:34:32 PM. by D.P.S. Forum started by parth
3172
9909
2834
How do you get this high gloss finish..what is the material used
Last answer on 2/7/2010 8:59:56 AM. by ranjeetsaini. Forum started by vinita
2874
Steel calculation
647
Which companies can provide high-quality translation of medical documents?
Last answer on 6/30/2021 2:39:08 AM. Forum started by terimad
2817
north seeing house 900 sq.ft house models
Last answer on 4/16/2012 2:06:19 PM. by Gunjan Utraja. Forum started by usha
2567
4031
labor rate for RCC work
4067
England~Usa~Canada~Uae 91- 8769373431 husband wife (divorce) problem solution ba
Last answer on 1/3/2025 12:42:34 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:28 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:22 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:16 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:09 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:40 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:27 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:21 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:12 AM. Forum started by rupeshji
Isthikhara For ((Australia=London))08769373431 Love Marriage Problem Solution Sp
Last answer on 1/3/2025 12:40:48 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:42 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:35 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:26 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:20 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:13 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:06 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:00 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:39:54 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:39:41 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:39:34 AM. Forum started by rupeshji
HSD
Which are various types of door viewers for houses?
The Mini Scope door viewer is a unique 200 degree peephole that is designed to fit thin doors.
Outdoor
Outdoor Lighting
Outdoor lighting is essential to light up paths and walkways, outdoors, driveways, pools or other areas and improves s..
Centering
Garden
Garden Path Ideas
