Home -> Forums -> Construction -> Plumbing -> Diverters for Bathroom
Sat Feb 26, 2011Total posts : 2
perryjoseph
perryjoseph
Topic: Diverters for Bathroom
I have a Flat at 11th Floor which is being constructed. I have put shower Diverters in bathrooms. One of my friend told me that in flats a pressure pump is required to get adequate pressure when we use Diverters. Some body help me.
Sat Feb 26, 2011Post  #1
Ar. Suresh Kothari
 Ar. Suresh Kothari
Post subject: Diverters for Bathroom
Dear perryjoseph
If the over head water tank is at sufficient height, then you do not rquire pressure pump. If the apartment common water tank is on the top of your terrace then you will not get water in shower, hence to get water in shower sufficient head pressure is must
Ar. Suresh KOthari
Wed Nov 04, 2020Post  #2
Tap generally refers to a keg or barrel tap, though also commonly refers to a faucet which only supplies hot or cold water and not both. It also appears as a descriptor in "tap water. A single temperature tap is commonly found in a commercial or public restroom where the temperature of the water will be controlled by a separate temperature regulating valve that mixes hot and cold water.
3290
2325
I want to know the rates for delux bathroom with jaguar for 5*6 bathroom
Last answer on 9/17/2013 3:17:17 PM. Forum started by muaz
1315
my bathroom size is 6 5 renovate my bathroom latest design and plan newly
Last answer on 1/31/2017 11:54:36 AM. by S L Gupta (Civil Engg). Forum started by raj
1704
plan for bathroom size 4'*7'
Last answer on 8/18/2016 3:56:25 PM. Forum started by BALRAJ CHADDHA
1504
Last answer on 10/31/2017 12:00:07 AM. by S L Gupta (Civil Engg). Forum started by div
2321
1745
1560
if my bathroom is in between east-north direction so what i do
Last answer on 3/5/2016 9:16:02 PM. by JAI PRAKASH. Forum started by yogesh
1947
Bathroom in SW corner
Last answer on 2/3/2021 11:53:25 PM. by JAI PRAKASH. Forum started by Amit Sharma
2093
interioe
Last answer on 7/4/2020 2:57:31 AM. by S L Gupta (Civil Engg). Forum started by sunil kumar
3896
glass white marble
Last answer on 7/4/2020 2:25:37 AM. Forum started by kamal
3673
sunken slab
Last answer on 7/3/2020 11:00:06 PM. by S L Gupta (Civil Engg). Forum started by chethan
3661
CAN WE CONSTRUCT COMBINED BATHROOM AND TOILET IN NORTHWEST
Last answer on 5/31/2014 11:05:07 PM. by JAI PRAKASH. Forum started by VIKAS
1979
two bedroom with kitchendininghall with attach bathroom in 600 sqr feet land
Last answer on 7/2/2014 11:22:17 PM. by JAI PRAKASH. Forum started by RAJENDRAN
1980
sir i want 20'' to 20'' plan with 2 bedrooms,1 hall,1 kitchen,i bathroom,
Last answer on 9/11/2014 8:05:03 PM. by seema tyagi. Forum started by neeraja
1954
in which direction should be the bathroom according to vastu
Last answer on 10/24/2010 1:02:19 PM. by sabina vanjani. Forum started by edwin
2318
as per the vastu what is the best floor plain of my bathroom
Last answer on 11/20/2010 8:46:32 PM. by S L Gupta (Civil Engg). Forum started by sandip ghatak
4794
pl recommend the remedy if you have bathrooms in southwest corner of the house
Last answer on 5/17/2011 9:13:00 AM. by Nikita. Forum started by HARISH KHANNA
3412
Using marble in the bathroom
Last answer on 5/2/2008 8:41:26 PM. by Monika. Forum started by Dikshi.k
6270
Water Tank Quality
3114
Hot Water Tank
2914
Sand in Water
2561
2144
40515
2083
GI pipe Vs CPVC pipeline
2930
1754
2079
Toilets
1987
Wall mounted cummod vs normal
5054
2774
2387
1854
3074
Swimming pool
2541
water softner
2681
commode type and flush type
4193
to shut off water to house
Bathroom Pictures
Bathroom Lighting
Bathroom Accessories Part-4
Bathroom Decorating Ideas
Using
Small
Small Bathroom Ideas or Tips
