| Pooja room designs in wood Decorating Pooja Room is very important in an Indian home. The worship of lord spreading positive energy in the house. |
| Pooja Room Vastu Vastu governs positive and negative energy inside the house. Positive zones such as east, north and north-east give us.. |
| Decoration for Diwali with Diyas, Diwali Lights and much more How to do decoration for diwali? Know more intant ideas for Diwali decoration. Diwali festival, its significance, diya.. |
| Dining Room Vastu Dining room should be comfortable and warm. It should be located in east or west direction, usually adjacent to the ki.. |
| Living Room Color Schemes Paint Colors impart a beautiful effect in your every room if chosen perfectly. But sometimes the excessive use of bold.. |
| Living Room Flooring Flooring is major factor when it comes to design your living room. How you do the floors to make impression on guests... |
