Earth Filling
Tue Dec 29, 2009Total posts : 3
Ramrekha_vns
Ramrekha_vns
Topic: Earth Filling
I bought 4297.6 sqft plot. And constructed Boundry Wall all around evenly. The plot level is below 5.5 feet from main road. The B-Wall has support of 18 RCC pillers of 10 inches each at regular intervals. The question is that the B-wall, not filled with any filling materials in base -like mixture of piece stone, lime, red sand etc. Can i start construction of room wall on this.Will this be safe for future...? Please send comment. Thanks.
The comment above talks about the article   "Earth Filling "
Tue Dec 29, 2009Post  #1
Ramrekha_vns
Ramrekha_vns
Post subject: Earth Filling
Opps! -- In continuation ** The B-wall brick structure started with 20 inch above it 14 inch above 9 inch and stopped at plinth level.
Sat Jan 02, 2010Post  #2
For construction of house, proper foundation of wall is required to bear the dead load of wall, load of RCC slab/ roof and live load bear by the slab/ roof, load of parapet etc. To make room wall on boundary wall is not safe. For more detail you may take help from the Web site Ghar expert. Com and read article “Brick Wall Specification.” Link given below.
http://www.gharexpert.com/articles/Brick-Walls,-Pillars-Structure-1473/Specification-Bricks-Walls-_0.aspx
Tue Jun 07, 2011Post  #3
imran
imran
I did filling as in this article; but after one month when we watered the floor it again settled down. our filling was 6 feet.why?
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
1795
Earth Filling
Last answer on 1/30/2014 10:54:38 AM. by Ahmed. Forum started by Ahmed
1906
earth filling under floor
1393
45467
how much cu.m of earth can excavated by machine per day
Last answer on 4/3/2021 12:46:18 AM. by prasadtvp. Forum started by sherab tenzin
1848
I m in the process of constructing a house where the structure is already comple
Last answer on 7/9/2021 4:45:04 AM. by Karan. Forum started by Sandra
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by Girish
1813
I would like to construct building with Earth quake resistence
Last answer on 5/24/2013 12:11:09 PM. by S L Gupta (Civil Engg). Forum started by ananth
4443
lobar work quantity
Last answer on 10/15/2014 8:31:38 AM. by SANJAY DUSANE. Forum started by naresh
2180
pile work
2431
footing
Last answer on 7/21/2012 2:08:22 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
1786
foundatio
Last answer on 10/6/2014 1:25:17 PM. by S L Gupta (Civil Engg). Forum started by nitu
1844
House plan
Last answer on 12/29/2015 12:51:33 AM. by JAI PRAKASH. Forum started by Rohit Sharma
3866
2537
RCC column (pillar)
1662
Rainwater Saving Earth pits
Last answer on 9/28/2015 11:17:59 AM. by S L Gupta (Civil Engg). Forum started by Bharat Kumar
1343
Last answer on 3/4/2015 1:22:04 PM. by S L Gupta (Civil Engg). Forum started by jay prakash
3842
Earth Filling
Earthing
How does earth quake affect the building?
The outer shell of the earth called lithosphere is broken into plates which are in constant motion, moving at about th..
Which are various types of faults in electrical fitting?
These are three types of faults in electrical fitting: .Open Circuit Fault .Short Circuit Fault .Earth fault and ..
The Five Elements In Feng Shui
The Chinese recognise 5 elements which arise out of the interplay of yin and yang. Ideally there should be a balance o..
Electric
