Home -> Forums -> Construction -> Start Construction -> Earthquake Design - Plinth Band and Lintel Band
Thu Jun 12, 2008Total posts : 1
Kitan
Kitan
Topic: Earthquake Design - Plinth Band and Lintel Band
Now a day it is commonly necessary in some parts of  India to design a house that is Earthquake resistant. The two RINGS that most house must have are referred to as PLINTH BAND and LINTEL BAND. Basically they are concrete band with iron rods inside it. It is essential Plinth band and Lintel band are included in paper when you sign with a contractor and architect must also be notified. I have attached to PDF file to illustrate basic understanding of these two bands. You will need Acrobat reader to open the files.
Attachments: EQTip14.pdf on Thu Jun 12, 2008,
EQTip15.pdf on Thu Jun 12, 2008,&n
Thu Jun 12, 2008Post  #1
Love thy community
Love thy community
Post subject: Awesome
That is a great piece of information Kiten,  These are the things that no one really knows when they get to construct the building and the contractor never tells the house owner as it would require them to do additional work.  Thanks a lot for posting.
2302
2153
1702
1971
Last answer on 12/5/2015 11:13:14 AM. by S L Gupta (Civil Engg). Forum started by Rohit Sharma
9198
1363
How to design my house to be more flood and earthquake safe.
Last answer on 9/27/2018 1:25:04 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
5692
2681
My House design
1819
Boundary walls
Last answer on 12/10/2015 12:29:13 AM. by JAI PRAKASH. Forum started by Pooja
3626
show plinth design of small beautiful home approxematly 1500sft
Last answer on 6/14/2012 10:55:58 PM. by Gunjan Utraja. Forum started by manzoordar
1106
Are TMT's building really earthquake resistant
Last answer on 8/20/2018 12:14:24 AM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
1511
1684
2193
Size of the Roof Level Beam in RCC framed structure
Last answer on 1/30/2015 12:12:31 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
3658
2750
1172
2840
Choosing the right type foundation and structure for house
Last answer on 9/30/2011 11:52:30 PM. by S L Gupta (Civil Engg). Forum started by Vinod
3312
2236
2717
2313
2061
Earthquake
Types of arch
Earthquake
Earthquake safety tips
Earthquake can strike suddenly with very little warning. One minute you may be enjoying the company of your kids and f..
What
What is recommended size and shape of building for the protection in earthquake prone areas?
All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s..
Porch
Porch Designs
Ceiling
