Home -> Forums -> Construction -> Earthquake -> Earthquake Resistant Building Construction
Wed Dec 16, 2009Total posts : 1
A.S Rajkumar
A.S Rajkumar
Topic: Earthquake Resistant Building Construction
Very informative and the main thing is to adhere and incorporate in your construction.
The comment above talks about the article   "Earthquake Resistant Building Construction"
Thu Dec 17, 2009Post  #1
Asit Patel
Asit Patel
Post subject: Earthquake Resistant Building Construction
Shear wall Construction is certainly better then column and beam, as Bricks, if not layed properly, can cause the walls to collapse.
Earthquake-Construction Questions (22)
1105
Are TMT's building really earthquake resistant
Last answer on 8/20/2018 12:14:24 AM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
1509
2301
1362
How to design my house to be more flood and earthquake safe.
Last answer on 9/27/2018 1:25:04 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
2749
4254
6099
What is construction cost
1680
earthquake safe building
Last answer on 5/12/2015 2:55:33 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2406
IMPORTANT
Last answer on 7/4/2020 4:17:48 AM. by S L Gupta (Civil Engg). Forum started by carola braats
2557
2974
2121
2511
3802
22 x 63 size plot construction.
Last answer on 7/16/2015 10:39:22 PM. by JAI PRAKASH. Forum started by rajkumar pola
4263
860sqft construction
Last answer on 10/12/2015 6:35:12 PM. by Rahul. Forum started by Shivaprasad
2882
3601
How we Calculate Construction Cost
Last answer on 10/21/2014 10:35:00 PM. by JAI PRAKASH. Forum started by JEETU KALANI
1509
1680
1836
foundation
Last answer on 10/18/2013 4:09:57 PM. by S L Gupta (Civil Engg). Forum started by yu nandar
Earthquake
Fire
What
What is recommended size and shape of building for the protection in earthquake prone areas?
All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s..
Comparison
How to Design a Garage
