Home -> Forums -> Construction -> Cement -> Economical cement brand
Sat Jan 10, 2015Total posts : 3
Bhuwan
Bhuwan
Topic: Economical cement brand
Hi, Can anyone suggest me to decide what cement use for multi story construction, there are so many brand in the market, I am bit confuse, every company does the marketing, they said their product is best than others. If you suggest me the brand name which should be good in quality and economically.
thanks in advance
Mon Jan 12, 2015Post  #1
      The cement required for construction should be factory-manufactured from a reputed manufacturer. It must not be from the local plant manufacturer. Care should be taken that the cement is properly packed from the factory, not be hand packed locally. While taking supply of cement manufacturing date, grade and type should be checked. The cement should not be more than six weeks old from the date of manufacturing.See the link below for more information
http://www.gharexpert.com/articles/Cement-986/Purchasing-Guidelines-Cement_0.aspx
http://www.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1397
Thu Jan 15, 2015Post  #2
All are ok.
Sun Feb 22, 2015Post  #3
Bhuwan
Bhuwan
Hi, I found below information but I can't decide which one I use, also I checked the different brand they have 25-45 INR difference in price.
  1. The IS Code of Cement
    1. 33 grade ordinary Portland cement=IS: 269
    2. 43 grade ordinary Portland cement=IS: 8112
    3. 53 grade ordinary Portland cement=IS: 12269
    4. Rapid Hardening Portland cement   =IS: 8041
    5. Portland Slag Cement                     =IS: 455
    6. Portland Pozzolona Cement              =IS: 1489 part I and 2
    7. Hydrophobic Cement                       =IS:8043s
    8. Low Heat Portland cement              =IS : 12600
    9. Sulphate resisting Portland cement   =IS: 12330
currently I am using IS: 1489 part I Could you tell me please, If it is Okay for 4 story building?
Is IS: 1489 part I is lower than 53 grade or higher?
2264
Cement selection
2943
Last answer on 6/25/2009 5:16:44 PM. by rose. Forum started by dinesh
3074
3591
2811
IN independent house - min how much rcc thk required and re informcement steel spacing and size of steel
Last answer on 3/1/2013 6:22:20 AM. by Maharshi. Forum started by tkalaiva
2668
2962
1991
cables
Last answer on 7/3/2020 10:07:56 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2362
What is the brand of this bathtub?
Last answer on 12/17/2021 11:47:36 AM. Forum started by sanda
1254
1702
Last answer on 7/3/2020 11:20:06 PM. by S L Gupta (Civil Engg). Forum started by PCR.Manohar
3791
1878
column
2625
i want economical and attractive flooring for hospital setup and some goodloking
Last answer on 12/31/2020 2:45:51 AM. by Ajit Tareeka. Forum started by kanchan bhoite
3437
Any interior decorators in Hyderabad quoting economical rates for quality service?
Last answer on 8/13/2015 11:52:23 PM. by JAI PRAKASH. Forum started by Murali
3118
concrete brick or clay brick
2688
DOORS
28692
Good Plywood for woodwork
Last answer on 10/26/2016 8:39:11 PM. by JAI PRAKASH. Forum started by raghuam
13266
Steel Type
1669
Cement requirement
1784
RAW MATERIAL
3442
Type of Cement
2526
RCC Slab -Curing
2325
Materials
23817
Last answer on 2/17/2021 4:49:34 AM. by S L Gupta (Civil Engg). Forum started by vinu
2872
Types of Cement
2514
Cement
2734
Per Square
Last answer on 6/23/2019 11:56:29 PM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1282
1988
Cracks in concrete roof
1241
Last answer on 5/26/2016 12:44:58 PM. Forum started by SUNIL KUMAR
1741
2264
Cement selection
2903
Cost of Cement Plaster
1855
Last answer on 4/11/2014 2:04:43 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
2484
Cement and Grades
Last answer on 6/13/2013 2:45:08 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
3040
2434
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by ravi at Dalmia. Forum started by Hemanth
Which are various brands of pipes for drainage of soil water?
Brands of pipes for drainage of soil water-C.I. Pipes-CIC..........
Cement Concrete Raw Material
Read points should be kept in mind while collecting raw materials for cement concrete in construction work.
Types of Cement
