Elctrical wiring
Mon Feb 08, 2016Total posts : 2
kumarakrishnan
kumarakrishnan
Topic: Elctrical wiring
how to prepare estimate Electrical installation  for 1000 sq.ft building
Mon Feb 08, 2016Post  #1
       Learn from estimate book.
Sat Mar 05, 2016Post  #2
It will cost you around 100-120/Sq.ft. Depending upon the drawing and brand you select.
2962
2722
electrical
Last answer on 7/3/2020 9:50:06 PM. by JAI PRAKASH. Forum started by sunil kumar
1923
chick door
18383
1568
wiring run above ceiling
Last answer on 6/20/2016 12:13:42 PM. by SW Psychology. Forum started by krish
1960
2225
electric&wiring
Last answer on 7/7/2021 8:59:47 AM. by JAI PRAKASH. Forum started by sunil kumar
2022
3238
2466
1939
Is it necessary to put iron wire under tiles at enterance of all doors in house?
Last answer on 9/18/2013 3:11:29 PM. by S L Gupta (Civil Engg). Forum started by bakula
2431
Electic wires
Last answer on 1/17/2014 12:15:51 PM. by S L Gupta (Civil Engg). Forum started by rajesh
2338
electrical installation
Last answer on 11/27/2021 2:32:14 AM. by Navneet Jharia. Forum started by brajesh pandey
2304
Electrical Wiring
Last answer on 5/16/2013 12:22:40 PM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
35
REBAR COUPLERS
Last answer on 5/21/2011 11:58:19 AM. by Girish. Forum started by Girish
1797
3087
1511
Electrical wiring
Last answer on 11/1/2015 6:41:12 PM. by JAI PRAKASH. Forum started by ani
15
17
What is binding wire
Electrical
Electric
Electric Shock Proof Home
What are various tools used for the installation of Fluorescent tube light?
Fluorescent light tubes come in many shapes and sizes. An increasingly popular one is the compact fluorescent light bu..
Protection
Protection against Mosquitoes
A few diseases like Dengue and Chikungunya have resulted in expressions of confusion all around. These diseases are tr..
Earthing
Energy
Energy Saving Tips
Saving energy will definitely help you minimize your energy/electricity bills. Here are some nice tips to save energy;..
Types of Glasses
A variety of glasses enriches interiors and exteriors of house and serves the purpose of light, ventilation and decora..
