Home -> Forums -> Construction -> Start Construction -> Electrical Conduits
Electrical Conduits
Tue Apr 29, 2014Total posts : 2
ajaywahi
ajaywahi
Topic: Electrical Conduits
Is it better to lay conduits (for carrying electrical cables) while casting roof or underground ( marble /stone) or false ceiling?
Could you advise the pros and cons of each of the 3 options:
1. While casting roof
2. Underground before laying marble
3.  Before False Ceiling being done?
Ajay 9810027979
Wed Apr 30, 2014Post  #1
Dear Ajay
       Conduit pipes is better if you laid during the RCC slab.
It is equally good before false ceiling but some time their fitting may be loose.
 Conduit should not be laid under floor.
Under floor there is problem of sanitary and water line , which cause leakage at any time.Also crossing of line is creates problem.
Wed Apr 30, 2014Post  #2
ajaywahi
ajaywahi
Dear Mr Gupta,
Many thanks for your advise. Actually for every room, we have laid one 25 mm while RCC slab being done but to be on safe side, i am putting one more 25mm pipe in False Ceiling!
When you say, they may loose, means I need to ensure they are tightly clamped to avoid lose?
Best
AW
1906
1524
2275
Ac and Electrcial
3752
1767
Electrical Conduits
Last answer on 5/9/2014 7:35:42 AM. by ajaywahi. Forum started by ajaywahi
2254
Electrical Conduits
Last answer on 5/20/2014 1:25:16 PM. by ajaywahi. Forum started by ajaywahi
2849
5686
2911
Last answer on 1/5/2022 12:27:42 AM. Forum started by Vineet Sethiya
3086
2550
Factory Main Door
2567
cost of electrical
11692
2347
1971
Elctrical wiring
2186
2022
1960
2962
3310
2133
2059
Electric
Electric
Electrical
Electric
Electric Shock Proof Home
Earthing
Switches
