Home -> Forums -> Construction -> Layout and House Plans -> Electrical Conduits
Electrical Conduits
Wed May 07, 2014Total posts : 4
ajaywahi
ajaywahi
Topic: Electrical Conduits
One electrician told me  that one should clamp the conduits ( on wall/roof) carying the electrical wires because in case it becomes lose and touches the steel frame of the false ceiling, it could cause earthing which in turn can cause fire.  Is this true?
Best
Wed May 07, 2014Post  #1
Dear Ajay
       Any defects in electric fitting can be dangerous at any stage.So one should follow the instruction carefully to avoid any mishap.
Thu May 08, 2014Post  #2
ajaywahi
ajaywahi
Dear Mr Gupta,
Kindly help me to understand, while for sure I will clamp the conduit on walls / roof but as these conduits are PVC , why should earthing issues happen if the wires are inside but the pvc conduit is touching the mild steel of the false ceiling frame?
On the other hand, even when you put the pvc conduit while casting of roof, it could be in touch with the Sariya ( Iron)?
regards
AW
Thu May 08, 2014Post  #3
I think Conduits should be fixed with roof and wall.
Fri May 09, 2014Post  #4
ajaywahi
ajaywahi
Thanks Purvi for your response. Yes, I will clamp them on roof /wall but my question was to understand why pvc conduits just in case touch the steel frame would cause earthing issues?
aw
1906
1524
2275
Ac and Electrcial
3752
2254
Electrical Conduits
Last answer on 5/20/2014 1:25:16 PM. by ajaywahi. Forum started by ajaywahi
2849
2002
Electrical Conduits
Last answer on 4/30/2014 3:32:30 PM. by ajaywahi. Forum started by ajaywahi
5686
2911
Last answer on 1/5/2022 12:27:42 AM. Forum started by Vineet Sethiya
3086
1971
Elctrical wiring
11692
2550
Factory Main Door
2567
cost of electrical
2347
2186
2022
2962
1960
2690
2924
2188
2184
2790
4520
1890
2284
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
Electric
Electric
Electrical
Electric
Electric Shock Proof Home
Earthing
Switches
